Glow and Light up Emblem
Old 12-16-18, 03:51 PM
taktiks
taktiks's Avatar
Originally Posted by TonyN
Tap wire into your brake running lights so it comes on when your lights are on.
Biggest issue is you need to drill a small hole to feed the wire, I do not want to drill into my trunk behind the emblem, these lights will fail eventually like all other aftermarket led products.
I believe there are two pegs on the back of the stock emblem, so there shouldn't be a need to drill holes. I might be mixing this up with the 2IS rear emblem though. You would probably tap into the parking light 12V wire just like the LED reflectors that iJDMtoy sells.
Amiefae (06-20-20)
Old 12-16-18, 04:46 PM
TonyN
TonyN's Avatar
I might try this if there is holes already
Old 12-16-18, 04:55 PM
darkfire
darkfire's Avatar
Subscribing. Let us know if you go for it, Tony!
Chris
Amiefae (06-20-20)
Old 12-16-18, 05:12 PM
TonyN
TonyN's Avatar
Chris
unless I get confirmation there are holes to fit the wires I wont try, definently not going to drill into my trunk
Old 12-18-18, 12:27 AM
Wsitywim
Wsitywim's Avatar
X-lume.com makes custom emblems. can have solid color or color shift.
smt6
04-08-16 11:08 AM
dbs600
07-14-14 01:28 PM
lilcop17
IS F (2008-2014)
13
10-04-12 02:05 PM
jecko714
04-22-07 11:54 PM
Kizoku
09-08-01 09:52 PM
Quick Reply: Glow and Light up Emblem
