How bad will these wheels poke out?? Volk GT-C 19x8.5/9.5 +27mm +24mm
Fronts: 19x8.5 +27mm
Rears: 19x9.5 +24mm
I found a ridiculous deal on these wheels, I have always like them. Really would like to run them, how bad will it be? I am not planning on lowering, if I do it will be RSR downs most likely. I will run a stretched tire if I have to, just wondering how bad these will be? If possible at all, I have seen these specs on 2IS's, sits basically flush.
Thank you!
Rears: 19x9.5 +24mm
Thank you!
How far out do you think in the rear?
They should be flush in the rear with 9.5 or have some very minor poking. The offset is low, but they aren't that wide so you should be ok. Rubbing wise you'll still have some issues.
Yeah I think I am getting them, I will probably get them powder coated, not a fan of the polished lip look really. Probably do a gloss black barrel with a satin or matte black spoke section. Or leave it gunmetal not sure yet.
sincityIS
07-11-07 07:26 PM
