Will putting new lowering springs damage original shock in the long run?
Old 07-31-14, 12:35 PM
JB5674
JB5674's Avatar
Just an FYI -
The stock shocks are Tokico's
I have down springs, I just keep it in sport + all the time. After intake and exhaust, if I drive w/o my lead foot, the MPG's arent too bad either. I see over 20 all the time in the city on a 350 Fsport. .
Old 09-12-14, 08:39 PM
SCSurf
SCSurf's Avatar
Originally Posted by a790
If you are looking at upgrading to those, at this point I'd recommend that you get some lowering springs and a decent set of aftermarket shocks and get them all done at once.
EDIT: Apparently the RSR springs are designed with stock shots, though they offer a modest drop (2.5-3 cm front, 2-2.5 cm rear)
Where'd you find that info?
Old 09-13-14, 11:37 AM
ISISGUY
ISISGUY's Avatar
I had springs with a 1" drop all around on my previous car. Installed them after owning the car 3 years and springs were on for 6 years after that. Never replaced shocks and I live in L.A. I think what helped me personally is that I learned to drive a lowered car. That's really what's going to provide the longevity. I avoided big dips, as many pot holes as possible, and maneuver in and out of driveways, all that good stuff. Any mechanical parts can go out for a variety of reasons, stock or not. Obviously, coil overs are always going to be the best option but just springs, depending on the drop and driving style/habits, is doable for a good amount of time. Just my opinion.
Old 09-14-14, 03:00 AM
Dawa
Dawa's Avatar
ok so the reason that "stock" shocks tend to "blow" sooner with lowering springs is because the stock shock and spring combo are designed to work together. together they USUALLY have a set amount of travel (in this instance we are talking about the compression stroke.) by adding lowering springs, you are compressing them by 1" (or however much the springs lower you) now you only have 1 less inch of travel in compression (hence the sometimes harsher ride associated with lowered vehicles. and that compression caused by the lowering springs is constant, 24/7, rather than just your shocks compressing sometimes when driving, which will cause the shocks to... expire sooner
Old 09-14-14, 09:03 AM
gvan1998
gvan1998's Avatar
^ Well said
Old 09-14-14, 09:27 AM
1sWt2GS
1sWt2GS's Avatar
my honest opnion, save up for coilovers.
Old 09-14-14, 11:34 PM
Dawa
Dawa's Avatar
+1. you will spend the money and then in a few months realize you wish you went coilovers. so the money will have been a waste. and when you get coilovers, make sure you research (here & google) on a "good" brand. by this i mean, dont just buy the cheapest coilovers because you want coilovers so bad (i made that mistake in ......06)
Lexicious
Suspension and Brakes
07-12-13 06:08 PM
mbud
13
03-13-07 05:38 PM
NesTea420
21
02-25-05 04:30 AM
GSpeed
01-31-05 02:06 PM
Quick Reply: Will putting new lowering springs damage original shock in the long run?
