wheel size
Old 09-07-14, 07:24 AM
jbkhat303
jbkhat303's Avatar
Default wheel size
will a 19x9.5 et 22 front and 19x10.5 et30 rear fit on the 3is without issues? Im not currently lowered but will eventually do a small drop. Maybe on some Downs.
Old 09-07-14, 03:32 PM
afdavey
afdavey's Avatar
You need to use the 'search' feature as this topic is discussed routinely on CL.
Based on the offsets you noted, you will need to go with more positive offset (higher #). Don't look to put too much wheel under the car - as you mentioned you will lower - most guy's try to 'cram' all the wheel they can - say it does not rub - and a week or two later are back on the site with rubbing issues.
Do some reading / researching - start with knowing what you have 'stock' and begin planning from there. There are websites that offer 'fitment calculators' to compare wheel/tire set-ups. Use these!
I like this one...
http://www.rimsntires.com/specspro.jsp
Old 09-07-14, 06:03 PM
Mr_VFS1
Mr_VFS1's Avatar
I'm running 20" but my offsets are 38/45 with RSR Downs.
jeeper2269
01-06-20 07:54 AM
truenoboy
07-20-08 12:11 AM
bwoodwrd1
07-18-07 08:44 AM
MKIV98TT
Wheels, Tires & Brakes Forum
06-29-07 04:51 PM
MrMark
07-19-06 05:50 PM
Quick Reply: wheel size
