Changed out my battery the other day
It was one of the most difficult battery swaps I've ever done...
I chose the Odyssey extreme battery. Purchased from Amazon.
The point of this post is that the OEM battery was leaking from one of the cells... Seems poorly made...
Perhaps this is why some owners are having dead battery issues...
Why not take it back to the dealer and have them replace the battery with a new one? Which I assume would have been a warranty claim and thus a zero cost item to you.
I went to the dealer when my car didn't start because I want a paper trail. I encourage others to do the same to put pressure on Lexus to resolve the issue. To me, it seems like there's more going on here than just a batch of bad batteries.
And this is another great reason to head back to the dealership. This is the only way to attempt to hold Lexus accountable for the issue. They can't address what they don't know about. And yes, I do know this may be an on-going issue others have experienced and reported.
I've never had a problem with the car not starting. It's been six months but i noticed that the stock battery was about half inch from being full. So plenty of battery was leaked out...
I also make it a habit to change out stock batteries as I never have luck with them lasting more than a year or so
When you say that are you taking mechanically, electrically or both? Did you need a ODB II scanner to clear any codes (check engine light, etc) after the swap?
I have a battery tender that plugs into the 12 volt port (formerly known as the cigarette lighter ) and I was thinking of using it as a "keep alive" when my battery needs changing. Modern cars have way too many things that need to be reset. It's not like the old days where you just need to reset your clock and radio stations.
I used something to save the memory. But that wasn't the hard part...
There are these two damn clips that hold the positive cable to the battery housing. I could not figure them out for like 30 mins. Had to google search how to..
The replacement battery was just a little bigger so I could not replace the battery cover. I don't think it's necessary because heat would get to the battery regardless.
I have a battery tender that plugs into the 12 volt port (formerly known as the cigarette lighter of ecig called itaste vtr) and I was thinking of using it as a "keep alive" when my battery needs changing. Modern cars have way too many things that need to be reset. It's not like the old days where you just need to reset your clock and radio stations.
I did the same thing not too long ago. Car had about 4500 miles and I went out to the car one day and "bam" dead battery. Went to the store and picked up an Optima Red top for the car. I was actually planning on doing this anyways, just not so soon. I've ran a Red Top in almost all my past cars and even a yellow top in my FJ Cruiser (big stereo and a lot of external lights).
I would have brought it to the dealer but this was after hours and I was in need of the car. Luckily I have an awesome neighbor that gave me a ride to the parts store that evening.
To prolong battery life, i usually pop the hood on my car when i get home so the engine heat doesn't soak the battery.
I did this on my old Honda Accord which lasted me 280K miles...
