RS*R Down Camber Wear...
Old 08-09-17, 01:38 PM
  #31
LeeJonah
LeeJonah's Avatar
Originally Posted by davyjordi
i bought the spc camber arms yesterday and will have them installed friday. i haven't driven much on the tires that are on the car now and the rears are the ones that are visibly showing the excessive negative camber. i hope this works because i don't want to have to spend a grand every six months on tires.
let me know if you have any rubbing issues with RSR downs with stock wheels after installing the camber arms and getting an alignment! Thinking about picking up the SPC arms too
Old 08-09-17, 03:37 PM
  #32
davyjordi
davyjordi's Avatar
i'm not on stock wheels. i'm on 19" f-sport wheels from the previous generation IS.
Old 08-09-17, 05:59 PM
  #33
LeeJonah
LeeJonah's Avatar
if it doesn't rub on your setup, it shouldn't rub on stock!
Old 08-09-17, 10:16 PM
  #34
jkonquer
jkonquer's Avatar
Didn't you just change your suspension? and it is showing the wear already? that's crazy
Old 08-10-17, 05:26 AM
  #35
davyjordi
davyjordi's Avatar
it's not showing wear. rather, i'm having camber arms replaced as preventative care. by visibly showing I meant just that, that one can see the camber or the tilt of the tires. by installing the camber arms i'll fix everything (hopefully).
Old 08-15-17, 02:27 PM
  #36
SceneAmati
SceneAmati's Avatar
Did you end up getting the SPC Camber arms installed?
I'm on RSR downs on my IS350 F-Sport and experiencing the same issue with tire wear.
I'm running 19" Velgen VMB5 wheels. 19x9 in the front and 19x10.5 in the back.
Old 08-15-17, 03:29 PM
  #37
davyjordi
davyjordi's Avatar
They are going to be installed next Monday.
Old 08-22-17, 05:52 PM
  #38
SceneAmati
SceneAmati's Avatar
End up getting your camber arms installed?
Old 08-23-17, 05:56 AM
  #39
davyjordi
davyjordi's Avatar
no, they didn't fit as i bought the spc camber arms for the 2IS. i have to now purchase the 3IS ones, but i'm a little hesitant because another member/friend of mine here was told he had to raise the car in order for the camber arms to fit and i really don't want to have to raise the car as i think it looks perfect. i have to do some more investigation before i proceed.
Old 08-23-17, 06:09 AM
  #40
Sheddy
Sheddy's Avatar
Looks good! I recall you wanting a conservative drop. lol
  #41
SceneAmati
SceneAmati's Avatar
Raise it? Hmm.. was he on RSR Downs too? I am on RSR downs and experiencing camber wear.
My left rear is -1.9 and my right rear is -2.5.
Definitely looking into SPC Camber arms, but I don't think I'll have to raise my car. The rear doesn't look like it'll be a problem. But, might be if I hit big dips. Not sure. I am going to order them this week and see how it goes. I might get away with -1 to -1.5 camber to save some tire life.
Here's a picture of my left rear
Old 08-23-17, 07:09 AM
  #42
davyjordi
davyjordi's Avatar
so much for that haha
Old 08-23-17, 07:13 AM
  #43
davyjordi
davyjordi's Avatar
no, he is on rs*r sport-i coilovers. we both have negative camber primarily at the rear of the car. you probably won't have to raise your car because well it can't be raised on springs and you're already at a higher point to begin with. my car is lowered far more than yours is and I'm running around -2.5 (camber) in the rear.
also, that's what my tires look like from behind, too. I don't want to raise the car, so I might just be buying new tires more often than someone who isn't running such negative camber.
p.s. let me know how it goes if you wind up buying and installing the spc camber arms please.
Old 08-23-17, 10:02 AM
  #44
600rr
600rr's Avatar
If you have symmetrical tires, you can unmount them and flip it. That would get a few more thousand miles out of your tires.
Do not attempt this if you have asymmetrical or directional tires, as it would wear out even faster.
Old 08-23-17, 10:49 AM
  #45
davyjordi
davyjordi's Avatar
that's a good idea. i'll have to look into that. thanks!
Quick Reply: RS*R Down Camber Wear...
