Aftermarket Wheel Showcase - 3ISx Exclusive
Old 12-28-18, 03:36 PM
  #1501
jmull3r
jmull3r's Avatar
Originally Posted by Sasnuke
If the offsets were swapped, then you would be ok.
The front is hard to say because with the +38 offset it really comes down to rim design if it will clear at this point.
The rear is gonna stick out past the fender a little. It might tuck in enough when the suspension compresses and clear the fender, but it's gonna be close.
the rim design is concave... and how far out would the rears stick out? would it be better off to not get them?
Old 12-28-18, 04:12 PM
  #1502
Sasnuke
Sasnuke's Avatar
Received 1,737 Likes on 1,370 Posts
The rear wont stick out a ridiculous amount, but definitely noticeable when compared to the front. The top of the rim should be just about flush with the fender, which means the rest of the rim would be outside the fender when you consider the natural negative camber of the rear, plus being lowered.
The safe bet would be to pass on them, but it's up to you.
Old 12-28-18, 07:28 PM
  #1503
EvilJoker
EvilJoker's Avatar
I'm running 19x9.5 +45 in the rear with a 275/30-19 and they are close to the fender. I think 40 would have been dead even with the fender. 30 would be beyond the fender I'm sure.
Old 12-28-18, 07:29 PM
  #1504
EvilJoker
EvilJoker's Avatar
Old 12-29-18, 01:35 PM
  #1505
jmull3r
jmull3r's Avatar
i found another pair same sizes but the front is +37 and rears are +38
Old 12-29-18, 01:36 PM
  #1506
jmull3r
jmull3r's Avatar
Originally Posted by EvilJoker
looks the same as her car haha same color and everything she just has a 250
Old 12-29-18, 01:38 PM
  #1507
Sasnuke
Sasnuke's Avatar
Much better. Worst case you can use a small spacer on the front if needed.
Old 12-29-18, 09:44 PM
  #1508
EvilJoker
EvilJoker's Avatar
I reeeeaaaally wanted a white one, but I got too good of a deal on this one.
Old 01-01-19, 09:47 PM
  #1509
Jaypmanuel
Jaypmanuel's Avatar
Is anyone on RSR superdowns on AWD with
fronts 18x8.5 +35
rears 18x9.5 +35
with stock 225/40 and 255/35 tires? Wanted to know if theres fender work to be done
Old 01-01-19, 10:04 PM
  #1510
Jaypmanuel
Jaypmanuel's Avatar
Originally Posted by SunnyHMoon
Gram Lights 57dr
F: 18x8.5 +38
R: 18x9.5 +38
Lowered on RSR Downs.
Nice setup! If you dont mind me asking, are you on stock 225/40 and 255/35 tires? I got an eye on the same spec rims but with an offset of +35 but ill be lowered on superdowns..wanted to kno if you rub at all?
Old 01-02-19, 11:05 AM
  #1511
cliffhokie
cliffhokie's Avatar
Don't suppose you put the springs on yet? I'm curious over your tires, most people I see are running 235/35R19 and 265/30R19, yours would give a little meatier tread and hopefully more tolerable ride comfort.
Also wondering if anyone has run anything like 235/40/R19 and 265/35R19.
Old 01-02-19, 02:35 PM
  #1512
EvilJoker
EvilJoker's Avatar
Most people are running less offset than me, so I figured with more offset I could add more tire. I will have them on soon, and will post plenty of pics.
Old 01-02-19, 03:52 PM
  #1513
jmull3r
jmull3r's Avatar
the fronts aren’t concave on these they look a little pushed out so they should clear the bigger brakes fine right?
Old 01-06-19, 07:56 PM
  #1514
VisualEcho
VisualEcho's Avatar
Finally got my Ace Alloy wheels on. Many thanks to Sasnuke, Lexi90, Max6133, and EvilJoker for the help.
LexoticJ (01-29-20)
Old 01-06-19, 08:05 PM
  #1515
Sasnuke
Sasnuke's Avatar
Aced It. by Andrew Thompson, on Flickr
Looking good
VisualEcho (01-06-19)
Quick Reply: Aftermarket Wheel Showcase - 3ISx Exclusive
