Aftermarket Wheel Showcase - 3ISx Exclusive
#1591
#1592
![](https://cimg1.ibsrv.net/gimg/www.clublexus.com-vbulletin/600x557/600600000niche_verona_bm_5b9b033f0793771117963b3af691857a6406ba56.jpg)
I am wanting to buy Niche Verona black wheels in this size:
18x8 40mm front
18x9.5 40mm rear
Right now, I have stock 17s, square set up, on the RWD 2014 is250. Would I have to change anything besides, obviously, needing new tires? Also, what size tires would you recommend?
Thanks in advance!
-Chris
#1593
Received 1,737 Likes
18x8 40mm front
18x9.5 40mm rear
Thanks in advance!
-Chris
18x8 40mm front
18x9.5 40mm rear
Thanks in advance!
-Chris
18X9.5 would be a 265/35/18
You might consider a slightly wider wheel on the front...maybe an 18x8.5 if available.
#1594
18x8 40mm front
18x9.5 40mm rear
Thanks in advance!
-Chris
18x8 40mm front
18x9.5 40mm rear
Thanks in advance!
-Chris
TSW and Verde also have a similar style.
#1596
Depending on the rim design you may or may not clear the caliper if your IS is anything other than a 250.
Is there any option for the offset? For example, can you get a +32 or +35.
Is the car lowered, or do you plan on lowering it?
Colorway (03-06-19)
#1597
The rear you would fine...the front is a little bit of a question mark.
#1598
Worst case if the front doesn't clear then a small spacer may be needed.
Colorway (03-07-19)
#1599
Colorway (03-08-19)
#1602
That should give you a nice ride for awhile and take care of the rear alignment issues since you'll have tons of Camber in the back.
With the front it will have some adjustment for Camber because it's an AWD...so cross your fingers it's enough.
#1603
You should be good...but considering the age and you're going with Superdowns, if funds are available, replace all the struts and install a set of SPC rear cambers arms.
#1604
If not, then it's still worth to do all of them.
The front have to come out anyways, so there shouldn't be any extra labor.
If one rear is already getting replaced, then it's just a little extra labor to replace the other.
