Aftermarket Wheel Showcase - 3ISx Exclusive
#1651
Received 1,737 Likes
There is a way you can make a larger tire fit easier by making the wheel itself larger (perfect size/offset), as it crowns the tire.
I discussed this very thing with a chap here once, and we came up with the following:
Front: 19 x 9 +35 with 245/40
Rear 19 x 10.5 +45 with 285/30/19
It would take a slight increase in negative camber, front and rear to make it work, but we think it would work.
But I think those are about the limits. Does that seem about right @Sasnuke ?
The following 2 users liked this post by Sasnuke:
Dzjnmstrd (04-01-19),
VisualEcho (04-01-19)
#1652
Did we have the front limits about right as well? Or are we off there?
#1653
But like all things with rims and tires, vehicle height and rim design need to be factored in.
You can't slam it on Superdowns on a 245 and expect it not to hit something. Also to clear the caliper, +35 is not a guarantee if the rim spokes don't curve outwards enough from the center on the initial distance.
#1654
The fronts would be fine too.
#1656
Hi Guys,
Trying to buy some Volk SF-Winnings for my '15 F Sport 350. I'm lowered on RSR downs.
They are:
Front: 19''x 8.5" +38 offset with 255/40/19 tires
Rear: 19"x9.5" +29 offset with 275/40/19
Will these fit or will there be any issues?
Thanks!
They are:
Thanks!
#1657
Short answer...no they won't fit.
#1658
As for the rear, I think +38 on a 9.5" wide is as far as you can go without rubbing.
Those numbers are assuming you're running a tire setup that is about square with the lip, or even slightly stretched to clear the fenders.
For example:
Front: 19x8.5 +32 245/35
Rear: 19x9.5 +38 265/30
This will also depend on tire brand. YMMV.
#1659
#1660
I probably should have checked on here earlier before ordering... But I just ordered SSR GTX01's 18x9.5 +40 square setup. I'm lowered on Swift Sport springs, will I have any trouble running these? Would spacers help? What tire specs do you guys recommend?
#1661
The front will likely hit the steering knuckle. Since you're running a square setup, you'll need the same size tire on the front.
You'll need a spacer for the front...but until you get the wheels to test fit, you won't know how big. I would guess a 10mm spacer at least.
Of course it might look funny with the front wheels poking out.
Really a 9 inch for the front is the biggest you wanna go.
etcetera (04-10-19)
#1662
Hello guy! Will rub on da rear. Front will be okey
#1663
#1665
