Aftermarket Wheel Showcase - 3ISx Exclusive
#1816
2018 IS300h
Lumarai Morro
Rear: 20x10 ET 44, Nankang NS-2 255/30
Front: 20x8,5 ET 37, Nankang NS-2 225/30
Dropped on RS-R Downs
Rubs a little inner fender in the rear when hitting big dips. Mostly rides just fine, no complaints!
Lumarai Morro
#1817
Yeah I'm probably just going to play around with spacers until I find the perfect match. Any idea if I should just go with RSR Downs over Half Downs? Half downs seemed a bit more reasonable with less scraping, but sometimes people will move my car for me. I really just want TE37SLs in the pressed graphite once in my life I guess haha. Its a nice rim that I can use on a variety of cars. Don't get me wrong though there are tons of other rims that look good and fit the IS. Just a personal preference. Its just a shame they've stopped making them and of the ones that they did make, the fitment is right for the IS. If I end up keeping the IS long term I might just do a video series of me shaving the rim down, heat treating it, and powder coating it to the perfect fitment. Appreciate all the insight and knowledge youve given me in the last few days
#1819
Received 1,738 Likes
If the offsets are correct, then the front you could run a 225/35/19 or a 235/35/19 (i would recommend the bigger tire).
The rear offset is a little low...the tire may rub on the fender depending how low you have the car. I would go with a 255/30/19 as your best bet to clear the fender.
Rebel3is (07-03-19)
#1820
Hey guys
I’m looking at getting a set of SSR’s GTV01. I currently have a 2017 IS200t (non-fsport). Would these fit?
Front: 18x8.5 +40, 225/40/18
Rear: 18x9.5 +45 (also has +22), 255/35/18
Thanks
Thanks
#1821
The rear rim specs are fine.
All the tires would be stretched.
#1823
What tyre sizes would u recommend?
Front: 235/40/18
Rear: 265/35/18
Thanks again
#1824
The likelihood is, at +35, you will be fine though. In my signature you will see I have spacers in the front...because my 20x8.5 +35 don't fit as the spokes don't curve enough when they initially leave the center portion.
The new tire sizes you quoted would be an appropriate fit.
I should correct myself from my last post...the tires would all be stretched, but it would be a 'slight' stretch.
The larger sizes you quoted would give a nicer ride and look a little beefer.
Realistically you could use both, but it will come down to ride quality, road conditions (lots of potholes or not), and personal preference.
Zokie (07-04-19)
#1825
+35 for the front would be good. With the big calipers in the front, rim design always plays a factor...spoke design can make one rim that is +35 fit, and another that is +35 not fit.
I'll try to go for the bigger tyres in that case, roads here are shocking and not planning on lowering the car even though I'm not a fan of the wheel gap.
#1827
Looking to buy Work Emotion T7R's. Will this set up work? 2015 is250 F Sport AWD - Airlift - Universal Air Bags. Will I be able to fully air out?
F: 19x8.5 +38 / is a 9.5 possible in the front?
R: 19X9.5 +38
Tire size recommendations? Also feel free to advise better specs if needed. Thanks.
R: 19X9.5 +38
#1828
Hey guys, here's my 2017 IS 200t on Junction Produce Scaras. 19x9.5 +25 square, Michelin Pilot Sport 4S 225/35/ZR19. Bagged, 8mm spacers in front, -4.5 rear camber (Megan Racing camber arms).
Ride height:
Ride height:
Spoiler
#1829
Your #1 Lexus Vendor
R: 19X9.5 +38
R: 19X9.5 +38
Tire recs are prob going to be a 225/255 or 235/55.
Contact us for pricing on those Works.
-Josh
__________________
Your #1 Dealer for Aftermarket Performance Products
Orange County, CA
Text/Call: 213 394 2886
Orange County, CA
