Aftermarket Wheel Showcase - 3ISx Exclusive
#1907
I tried searching, but didn't recall seeing this combo on an AWD, but would 245/35R19 front and 275/30R19 rear work on an AWD? Not asking about spacing, I'm relatively certain I can clear this without any issues, but wondering about the 1.2% difference in diameter between Front/Rear, which is slightly more than the 235/265 FR combo I'm currently running. I seem to remember someone saying 2% and below shouldn't affect the AWD system.
#1908
Looking to put some 19in wheels onto my 2018 Lexus IS300 F Sport RWD (Post Facelift IS)
Will lower it on AirLift Performance suspension or Coils soon as well.
Looking to get some wheels that are
19x9.0 +33 with 235/35/19 Tires (FRONT)
19x9.5 +38 with 245/30/19 Tires (REAR)
Will they rub?
Will they rub?
#1909
Received 1,738 Likes
Will they rub?
Will they rub?
And the rear you would want a little more offset if you're doing air as well...maybe +42 or so.
Also, is the rear tire size correct, or a typo? Cause a 245/30 is too small for a 9.5 inch rim...unless you're purposely trying to really stretch the tire.
#1910
When i look at the tire sizes, I look at circumference rather than diameter.
The stock F sport tires, even being staggered have a circumference of 25.1 inches.
The setup you are proposing will be 25.8 inches front and 25.6 inches rear. Also consider that variations in tire brand will have variation in exact circumference...could be a variance of 0.2-0.3 of an inch.
Given that they are not that much bigger than stock sizing, I don't foresee an issue.
With the AWD you're trying to keep the front and rear circumference the same...in this case it will be very close.
The speedo will be off, but not a tremendous amount.
I say go for it!
cliffhokie (10-07-19)
#1911
Likely you haven't gotten any responses on this as you did note that no one has done this combo on AWD.
I say go for it!
I say go for it!
#1912
I think you need to decide first if you're doing air or not...cause if you want to air out all the way down, then the front could be an issue...i would suggest an 8.5 inch rim in that case.
Hi Sasnuke,
I appreciate your time to respond to my question!
So I have decided to go with Airlift 3P with Performance Adjustable camber plate Struts.
I don't plan on airing all the way down, my choice to go with air suspension is really the streets in LA are horrid + my driveway, i would also like to keep comfortability into play while also getting a 1.25 to 1.5in drop max for drive height.
My front and rear I went with a minor tire stretch on the minimum tire you can run on these widths(Source: https://www.tyresizecalculator.com/c...rim-size-chart) just to due to look due to as im going with some Leon Hardiritt Ordens and personally want to stretch just a bit.
Following that response if i were to do a
19x9.0 +33 Standard Disk
19x9.9 +38 Low-Disk
Would these type of faces cover my brakes? I noticed the front on my car are huge and my rear are small.
Thank you again,
Alex P.
#1913
Does anyone know if this fitment will fit? These wheels are currently on 2IS lowered on coilovers with camber kit. I have a 3IS stock, but will get down springs.
Work VSXX 19x9.5 +24 and 19x10.5 +29.
Thanks
Thanks
#1914
The fronts are too wide and the offset is too low.
The rear offset is way too low...it would need to be +45 or higher to fit.
#1915
Hi Sasnuke,
19x9.9 +38 Low-Disk
Thank you again,
Alex P.
19x9.9 +38 Low-Disk
Thank you again,
Alex P.
By the numbers the rims should fit, but it's difficult to factor in spoke design.
Because it's a 3 piece rim, and the design of the face is fairly flat, it really depends how thick the backplate is. The backplate is the piece that will fit over the studs and sit directly on the rotor.
The rear won't be an issue, as you noted the brakes are small.
The front is where the concern is. If the backplate isn't thick enough, then the rim will hit the rotor...however, adding a small spacer will usually correct that...like 3mm or 5mm.
#1916
Thinking about ordering up a set of black Enkei TS9's for my Atomic Silver 16' 3IS. Was planning on switching over to a square setup, with a 18x8.5 +35 wheel with a 245/40r18 tire.
Looking at either a General GMAX AS-05 or a Goodyear Eagle Sport A/S. Any thoughts on fitment or recommendation on tire before I pull the trigger? Used for commuting, gets cold and occasionally get a light dusting of snow where I live, commuting about 100 miles a day. Factory ride height and no plans for lowering it.
#1917
The wheel specs looks like they should fit no problem.
You can up-size the tire to a 255/35/18...which is the stock size for the rear of an F Sport.
I'll leave the tire rec's for others to chime in on...over here we have winter, and not-winter lol...so my tire rec's won't be any good to you.
#1918
I'll leave the tire rec's for others to chime in on...over hear we have winter, and not-winter lol...so my tire rec's won't be any good to you.
Right now my car is staggered 255/35's in the rear and a 225/40 in the front.
#1919
Since you have the F Sport wheels already, the rear specs will basically be the specs for your new square setup, minus the offset.
Imagine adding a 15mm spacer to your current rear wheel, that's what the new wheels would look like for spacing.
To get more of a visual, you could also take your rear F Sport wheel and mount it on the front...just to give you an idea of what the new wheels would look like.
Keeping in mind you have to imagine it 15mm more towards the outside of the vehicle because of the difference in offset.
novaman64 (10-22-19)
#1920
Your #1 Lexus Vendor
-Josh
__________________
Your #1 Dealer for Aftermarket Performance Products
Orange County, CA
Text/Call: 213 394 2886
Orange County, CA
