Aftermarket Wheel Showcase - 3ISx Exclusive
Old 01-16-20, 08:52 PM
  #1981
TOPENDMS
Former Sponsor
TOPENDMS's Avatar
Originally Posted by Ghost ES3
yes, yes and yes... we need the spec of this. wow
http://www.artisanspirits.co.jp/car-...-bl/index.html
From what I seen .. when running 20s the best bet is to increase the wheel diameter by 1", so you would use the same specs but with 20" diameter.
Old 01-21-20, 08:30 AM
  #1982
C3RTIFI3D
C3RTIFI3D's Avatar
Default 18 te37
Trying to run this kinda setup with rsr downs I didn’t know if there would be any problems
I know that I would need some fender work but it says that no major mods where needed to fit them
if the guy is on here sorry for jacking your pics lol
Old 01-21-20, 01:09 PM
  #1983
C3RTIFI3D
C3RTIFI3D's Avatar
Nvm guys I talked with the owner and he said I wouldn’t be able to run these but gave me some tips to what I need to run.
Old 01-21-20, 01:46 PM
  #1984
Sasnuke
Sasnuke's Avatar
Received 1,737 Likes on 1,370 Posts
@C3RTIFI3D I believe this is the car you posted the pics of (I would consider that fitment to be major modifications, but that's me): https://www.clublexus.com/forums/bui...-build-14.html
Old 01-30-20, 01:58 PM
  #1985
Dev3is
Dev3is's Avatar
Originally Posted by Sasnuke
Damn...that's looking on fire!
We need some more pics!!!
I like the use of hubcentric parts and the ARP studs...looking good and staying safe!
Had the time to take more shots thanks to my buddy, oh man i love these wheels so much!
Alonzo3000 (04-12-20)
Old 01-31-20, 05:06 PM
  #1986
trinhtd
trinhtd's Avatar
Old 01-31-20, 05:50 PM
  #1987
Itzyaboijd
Itzyaboijd's Avatar
Default My 2015 Lexus IS350 Fsport | Rotiform KPS wheels
WHEELS TIRES
>Front | 20x8.5 30mm offset >225/35/20 Front
>Rear | 20x9.5 35mm offset >235/30/20 Rear
>Lowered with BC coilovers
>Fenders pulled in the rear because of the offset.
>Spacers on the front wheels because they did not clear the Brake calipers without them.
Florescent Yellow
Old 02-06-20, 01:34 PM
  #1988
CHAIVII
CHAIVII's Avatar
Default Anyone?
New member and owner of a 14' Lexus IS350 FSport AWD. Anyone running 18x9.5 +38 wheels on stock height? Recommended tires? I want to run a squared setup all around. All I'm seeing are staggered setups and was wondering if anyone is running a squared set up with 18's or is that even possible? I'm sure going with those wheels specs wont look too aggressive but I'm still indecisive about lowering. Again, new here, not sure if I'm posting this in the right spot or not.
Thank you for your time, hopefully someone can shed some light on my questions. If anyone has any pictures with those wheel specs and stock height, that'd be awesome too.
Old 02-06-20, 02:15 PM
  #1989
Sasnuke
Sasnuke's Avatar
Welcome to the forum!
In answer to your question there is one member running 18x9.5 square lowered: https://www.clublexus.com/forums/is-...l#post10670238
The link is pics of the vehicle and if you go down 2 more posts he indicates its 18x9.5 +38 with 255/35/18 tires and a 5mm spacer in the front.
Old 02-06-20, 02:32 PM
  #1990
CHAIVII
CHAIVII's Avatar
@Sasnuke Awesome, Much Appriciated!!!!
Old 02-06-20, 08:09 PM
  #1991
jameshan
jameshan's Avatar
Old 02-10-20, 07:38 PM
  #1992
melonbar
melonbar's Avatar
DarthLex (02-19-20)
Old 02-10-20, 10:46 PM
  #1993
PHASMA_3IS
PHASMA_3IS's Avatar
Weds Maverick 1105s
Old 02-14-20, 12:22 PM
  #1994
eddieendo
eddieendo's Avatar
Originally Posted by jameshan
THIS IS MY FAVORITE CAR ON HERE, what are your wheels pecs and will it fit stock suspension with springs?
Old 02-14-20, 12:34 PM
  #1995
eddieendo
eddieendo's Avatar
This is a tire sizing guide I gave to someone else. As is states in the first 19 inch recommendation below, offset will be dependent on the manufacture.
I don't have one for 18's prepared as usually folks stay close to the OEM specs if they go with aftermarket 18's.
Stock F-Sport Wheel specs
18X8 +40 225/40/18
18X8.5 +50 255/35/18
19 inch upgrade with staggered fitment (to keep the exact same tire circumference as the stock 18 inch wheels - no offset as that is wheel manufacturer specific):
19X8.5 225/35/19
19X9.5 255/30/19
19 inch upgrade with staggered fitment - with plus size on tires:
19X8.5 235/35/19
19X9.5 265/30/19
19 inch upgrade with staggered fitment - with plus plus size on tires:
19X8.5 245/35/19
19X9.5 275/30/19
this is so helpful thank you
justeeenn (04-19-20)
Quick Reply: Aftermarket Wheel Showcase - 3ISx Exclusive
