Aftermarket Wheel Showcase - 3ISx Exclusive
#2041
Trunks probably my favorite too! Went with the OEM hood and wished I went with one of the other styles from seibon
Sasnuke (04-03-20)
#2043
#2044
#2045
Can't trust those Canadians to get it right! lol
I'm digging quiet and smooth.
Weather is crappy hear too...hopefully the weekend is nicer and you can put them to the test.
#2046
Hey guys, first time member. I pulled the trigger on some Vossen HF3 19 inches, front 8.5 +32 and rear 9.5 +40. I wasn't intending to lower my car, after seeing some cars with same setup on stock suspensions. I am reconsidering it installing on stock suspensions. I went threw the forums to see what other people were running for suspensions. I am titled towards going for coilovers, the BC or RSR. since my car has over 100k kms. Would prefer BC but not sure if they work well on AWD, i have a 2014 is350. I know that RSR will definitely work but the price difference is pretty hefty. What do you guys suggest?
#2048
#2049
Since you car is 6-7 years old and 100K kms on it, and if you wanted a mild to moderate drop, then I would do the RSR Downs and replace the factory struts/shocks at the same time.
From a cost perspective that recommendation would be the same as getting coilovers...so my final thought is to go with the coilovers.
If you just put the springs now with the original struts/shocks, then it will shorten their life significant and likely you will be replacing at least two of them in the near future due to leaks.
Overall if you wanted more than a moderate drop, then the coilovers are the only way to way IMO. I look at it from the perspective of getting the look you want and the ride quality you expect out of a Lexus.
On a side note...hope you and everyone around you is keeping safe. Doesn't seem like the Covid situation in Quebec is going so well.
onenation (04-05-20)
#2050
If your vehicle was new, and you wanted a mild to moderate drop, then I would say just go with the RSR Downs.
Yeah Quebec got hit hard man... But it seems that everyone is taking it more seriously now, especially with the cops patroling the streets and giving up to a thousand $ tickets if you don't respect the guidelines. Hope you guys are also keeping safe down your neck of the woods.
#2051
Thanks for the feedback. I noticed that there aren't a lot of options for AWD's when it comes to coilovers, only found BC and RSR that offered coilovers that would work on my car but the price difference is pretty big between the two brands. I was leaning towards the BC but when i contacted a sales rep for BC, they weren't too sure if they would work. Any thoughts on the two brands?
I think overall they have positive reviews, so certainly you can't go wrong.
For the 3IS, the rear are all the same in terms of fitment, whether you have RWD or AWD.
The front is where they are different...and there are 3 variations.
There's the AWD which is the same across all years and models.
The RWD does have two versions...basically 2014 - 2016, and then it seems they changed it on the 200t in 2017.
Did the BC rep give any feedback as to why he thought it may not work?
We are hiding out over here trying to stay safe. Not so bad specifically where I am, but you definitely want to avoid Toronto and anywhere close to the GTA.
#2052
So I'm seriously considering buying these BBS SX wheels. The fitment is 18x8 5x114.3 +40. I'm on RSR Downs how would that play out? Thanks in advance for any help as I'm not very good at the whole aftermarket wheel thing.
#2053
Chances are you'd want to throw on 15mm spacers on all around anyways to try and flush them out...which would solve your potential clearance issue in the front at the same time.
#2054
My only concern would be caliper clearance in the front...otherwise size and offset are fine.
#2055
So just use my 20mm/15mm spacers that I知 using currently and it should look decently flush? I know stock wheels are 45 and 50 offset so if I知 running 20mm spacers on the front currently and 15mm on the rear wouldn稚 I need to get probably 20mm spacers for the rears since the offset is 40 on the BBS wheels? Also I changed my mind to the BBS XR but they have the same exact sizes and measurements.
Since most with the stock F Sport rim (18x8 +45) on the front with a 20mm spacer say that they could probably fit a 25mm, then that's exactly what you would have.
The BBS rim is out further by 5mm, so when you add your 20mm spacer, it would be the same as an F Sport rim with a 25mm spacer.
On the rear both the offset and size of the BBS rim differ from a stock F Sport rim (18x8.5 +50).
An 18x8 +40 is the same as a 18x8.5 +50 with a 4mm spacer...so if you add your 15mm spacer to the 18x8 +40 rim, it will be like the F Sport rim with a 19mm spacer...so basically stick with your 15mm spacer on the rear. Please don't ask me to write out the math for that LOL!
Flash5 (04-05-20)
