Aftermarket Wheel Showcase - 3ISx Exclusive
#2116
I tried to find those tires locally, but no dice.
First issue being some tire places are closed due to covid, so when i found one open, they weren't able to get it.
Ended up with the Firestone Firehawks...which are great tires, just a little more than I was looking to spend.
#2117
Hows it going guys, quick question on how you might think this fitment would look or if you've seen anything close to it? Haven't seen many 18 in wheels on here.
I'm looking to look as flushed as possible without rubbing while also maintaining function/performance. (This is a daily driver)
18x8.5 et35 225/35/18
18.9.5 et38 265/30/18
Wondering if RSR downs or superdowns would be better?
Open to any criticisms or editss of the set up!
Thanks in advance
Thanks in advance
As for the rims, the specs will fit no problem.
As for the tires you will need to rethink the sizes...you can't get a 265/30/18...at least I've never found one.
I have the same rim specs and I'm running 235/40/18 and 265/35/18...I'm hoping it will be warm enough soon so I can wash the car and post some pics.
If that's too much sidewall for you, then the stock F Sport tire sizes is your next option, 225/40/18 and 255/35/18.
#2118
I would suggest going with the RSR Downs...the Superdowns are quite a bit of drop, if you want it that low and still have a good ride, then coilovers would be the way to go.
If that's too much sidewall for you, then the stock F Sport tire sizes is your next option, 225/40/18 and 255/25/18.
#2119
mindoculus (05-29-20)
#2123
Vossen cv3 fitment
Curious to know if anyone knows how the fitment of 19x8.5 and 19x10 rims with 10 and 15mm offset would turn out on an is200t. Is it possible? Do i need to roll the fenders or throw on a spacer?
#2124
For a 19x8.5, if you want a super flush fitment, then +30 would be as low as you can go...depends if vehicle is stock height or lowered as well.
For a 19x10, you'd need a +45 at least to clear the fender...once again it will depend if the vehicle is stock height or lowered...also what tire size you want to run.
Rear fenders can't be rolled because they are factory rolled already.
Spacers would decrease the offsets more bring them closer to 0, which would make the fitment even worse.
Outside of a custom fitment, the 19 inch CV3 comes in 8.5 +32 and 10 +42...which could work.
Highfather (04-24-20)
#2125
With those offsets the wheels would be sticking outside the fenders.
#2126
#2127
Cleaned the vehicle today so I could take a few pics with the rims on.
GTS G709 in Satin Bronze
18x8.5 +35 with 235/40/18
18x9.5 +38 with 265/35/18
Tires are Firestone Firehawk Indy 500
No rubbing.
I don't post many pics, so I'm making up for it now.
No rubbing.
The following 5 users liked this post by Sasnuke:
arentz07 (04-27-20),
beadlock (04-25-20),
Flash5 (04-25-20),
kj07xk (04-25-20),
RageRacerM (04-25-20)
Sasnuke (04-25-20)
#2130
Read through the entire thread and it's definitely helped pick out my first set of wheels/tires. Can I get a paranoia check to make sure it's all good? (Sasnuke, this is gonna be super similar to your current setup lol)
Work CR Kiwami
18x8.5 +38, 235/40/18
18x9.5 +38, 265/35/18
Continental DWS06
On stock suspension right now, but needing a new set of tires due to inner wear on the fronts. have a set of the RCF bushings to solve that. Getting coils when I move to a place that doesn't have (4) nasty speed bumps in the parking lot.
Work CR Kiwami
Continental DWS06
