Aftermarket Wheel Showcase - 3ISx Exclusive
Old 05-17-20, 02:06 PM
  #2146
Tvankastel
Tvankastel's Avatar
Default New 19 inch CVR2 Concaver wheels hybrid forged
Installed new wheels last friday:
Concaver CVR2 in carbon graphite 19 inch
8,5J front +35
9,5J rear +40
235/35/19 front Yokohoma tyres
265/30/19 rear Yokomaha tyres
Car has been lowered on RSR titanium half down springs and has real carbon parts (LEMS sideskirts, splitter and rear diffuser)
The following 2 users liked this post by Tvankastel:
arentz07 (05-17-20), Sasnuke (05-17-20)
Old 05-17-20, 07:03 PM
  #2147
Sasnuke
Sasnuke's Avatar
Received 1,735 Likes on 1,369 Posts
8,5J front +35
9,5J rear +40
Nice wheels...don't think I've seen those before.
Maybe a 350 front caliper conversion to set off the space in the wheels.
Old 05-18-20, 12:46 AM
  #2148
ohkun
ohkun's Avatar
8,5J front +35
9,5J rear +40
Nice setup.
I was going for 9.5 +45 for the rear.
Maybe I should go for 9.5 +40 instead.
Any clearance issue?
Old 05-18-20, 03:49 AM
  #2149
Tvankastel
Tvankastel's Avatar
Originally Posted by ohkun
Nice setup.
No issues . Fits without trouble/modifications. Concaver is a new brand. They have nice wheels with good build quality and lightweight.
Big brakes will be the next modification
Old 05-18-20, 06:50 PM
  #2150
rk350
rk350's Avatar
19x8.5 +35 235/35/19
19x9.5 +40. 265/30/19
Niche Gamma w/Michelin PS4S
RS-R Downs
The following 4 users liked this post by rk350:
kj07xk (05-18-20), Napalvr (05-19-20), Sasnuke (05-19-20), Tvankastel (05-19-20)
Old 05-19-20, 10:17 AM
  #2151
Darbydarby
Darbydarby's Avatar
19x8.5/9.5 35
offset
Ebay wheels shipped to my door for $740.25
285/35 rear and fronts were 235/35 front on stock springs.Currently switching to a 245 up front because I don't like that stretched tire look. The rear scrubs on some harsh bumps. I would like to lower the front maybe 1/2".
Napalvr (05-19-20)
Old 05-19-20, 11:35 AM
  #2152
Napalvr
Napalvr's Avatar
Originally Posted by Darbydarby
19x8.5/9.5 35
offset
19x8.5 +32(235-35) 19x10+42(265-30) RSR downs. We’re twins....almost
You could try just down springs in the front
Old 05-20-20, 02:57 PM
  #2153
delata
delata's Avatar
Anyone know if a 18x9.5 +35 will fit without issues?
Old 05-20-20, 05:01 PM
  #2154
Sasnuke
Sasnuke's Avatar
If you're going square, then the front will be ok, the rear might be an issue depending on if you're lowered or not.
You would be using a 255/35/18 if you wanted to squeeze them onto the rear.
Old 05-21-20, 04:20 PM
  #2155
NikNikNik
NikNikNik's Avatar
I’m thinking about going with a staggered setup and was wondering if it would fit / would this be flush fitment
19” 8.5 +35
19” 9.5 +40
stock suspension for now
thanks in advance
Old 05-21-20, 11:21 PM
  #2156
3is200t
3is200t's Avatar
Hey guys, I just purchases ESR SR08 in 19x8.5 +30 and 19x9.5 +35 . What tire setup would be recommended?
I am currently thinkg of 235/35 and 255/35. Would this be okay?
I will be lowered on ARK springs.
Old 05-22-20, 04:36 AM
  #2157
Sasnuke
Sasnuke's Avatar
19” 8.5 +35
19” 9.5 +40
thanks in advance
No fitment issues...it will be close to flush.
Old 05-22-20, 04:42 AM
  #2158
Sasnuke
Sasnuke's Avatar
If you want 235/35 on the front, then the matching tire for the rear would be 265/30.
My only concern would be that with a +35 and 265/30 on the rear it's likely going to rub on the fender...depending on what tire brand you get.
You're best chance of it not rubbing is 255/30 on the rear...in which case the matching front tire would be 225/35.
The rim fitment is going to be super flush, so tire size is going to be crucial so there are no issues.
Old 05-22-20, 07:48 AM
  #2159
3is200t
3is200t's Avatar
So 225/35 front and 255/30 rear would be the best bet without any modification ?
Old 05-22-20, 09:10 AM
  #2160
Sasnuke
Sasnuke's Avatar
Yes...also try to avoid tires that have beefy sidewalls like Michelins.
If you do decide to got with a 265 or Michelins, then worst case scenario is you add some camber adjusting arms to the rear (like SPC) and give it a little bit more negative camber for the tires to clear.
At this point you're literally down to a matter of millimetres.
Quick Reply: Aftermarket Wheel Showcase - 3ISx Exclusive
