Aftermarket Wheel Showcase - 3ISx Exclusive
#2161
Yes...also try to avoid tires that have beefy sidewalls like Michelins.
If you do decide to got with a 265 or Michelins, then worst case scenario is you add some camber adjusting arms to the rear (like SPC) and give it a little bit more negative camber for the tires to clear.
At this point you're literally down to a matter of millimetres.
Only issue with these wheels are the rears. Front are okay.
And instead of 225/35 front can 225/30 work also?
Update: Achilles does not make 255/30 for sport tires
#2162
Received 1,737 Likes
225/35/19 will keep the wheel diameter as close to the stock size as possible...a 255/30 will actually make the diameter of the wheel smaller than stock, also no one makes a 225/30/19.
#2163
Kinda want to stick with achilles cus its the cheapest for its quality
#2164
Okay. I understand now. Btw, achilles tires actually doesnt make 255/30. Should I take the risk and get 255/35 or opt for a different brand? If so, which do you recommend with the wheel fitments. Im on a budget for tires. nothing too cheap or expensive.
Ideally I would look at a brand that has the correct sizes you need.
I'm not sure what the Achilles sells for by you, but maybe check out Sumitomo, Falken, or Hankook.
#2166
You could go with:
F: 225/35/19
R: 255/30/19
or
F:235/35/19
R:265/30/19
Personally I would go with the second one...more rubber + more sidewall=nicer ride
#2167
Sasnuke (05-25-20)
#2168
#2170
What wheel brands do you all suggest for the 3IS that offer wheels with correct offsets. I'm looking to stay under $450/wheel in the 18" or 19" size. Seems like the rear offset at 38+ or higher tends to kill a lot of my first choices.
#2171
If you want to go 9.5 in the rear (or wider), then +38 is a good starting point. The wider you go the higher the offset will need to be.
If you go with an 8.5 or 9 in the rear then the offset can be lower.
For brands of wheels it's completely subjective because it's really what you like vs. what's available where you are.
#2172
I recently ordered a set of custom AG wheels and I thought I was supposed to tell the offset and stuff like that, but I was told that the engineers would find the best offset for my car. Is this normally how it works when you order custom wheels? I’m new to this😅
#2174
Whats Up Nick I see you everywhere now lol. For the wheels, you got custom wheels so yes they have right measurement to have the "perfect" fitment unless you want it little more or less aggressive. There's plenty of people who got custom AG for our cars so they have plenty of measurement lol
NikNikNik (05-26-20)
#2175
