Aftermarket Wheel Showcase - 3ISx Exclusive
#2357
Received 1,735 Likes
The following 3 users liked this post by L3x14:
#2359
AquaMayne (05-31-22)
#2360
Might be a dumb question..
So my current wheels are cast 20's, and they seem to bend easily... I was going to go down to 18's to hopefully avoid bending wheels, but I just feel the larger rims look better.
If I got forged 19's, would the fact that they are forged and that I'd have more sidewall lessen the chance of bending rims in the future??
#2361
I’ve seen more cracked rather than bent cast wheels. Forged would give you a better chance along with a higher aspect ratio sidewall would help.
#2362
I just assumed they were cast because they seem to bend easily.
I was going to drop to 18's for more sidewall protection, but if can run 19's with more confidence than the 20's I currently have, I would do that.
#2364
OUCH!
Lumanari Riviera’s are rotary formed....they start as cast, and then they’re heated and spun on a roller press. Rotary forming is supposed to make the barrel and lip stronger - the center of the wheel doesn’t really benefit from the process.
The problem is that most people will run a 30 aspect ratio on 19’s. I assume that you can run a talller tire - but again probably a 35 or 40 aspect ratio at most. It’s gonna depend on the wheel width and offset too. Also instead of a staggered setup, you can run a squared setup.
#2365
OUCH!
#2366
There are plenty of people that run 19s with no trouble. However, what you’re experiencing is exactly why I choose to run a square 18” with a 245/35 aspect ratio setup.
#2367
20" Lumanari Riviera's, they were on the Lexus when we bought it. From the research I've done, they were a dealer option (or something like that). I don't know their width though, but the front tires are 245/30/20 and the rears are 275/30/20.
OUCH!
They’re also rotary forged wheels so not as strong as a true forged but they’ve been going strong for 3+ years for the most part.
I did get a really tiny bend on the inside of one of them from hitting a massive pothole but it wasn’t bad enough to where I can feel anything while driving and it’s not visible. I also had to replace one of the wheels earlier this year because I ran over an axle on the freeway and bent one of the rears beyond repair.
Just wanted to share just incase it could help with your decision.
LG80 (12-23-20)
#2368
#2369
![](https://cimg8.ibsrv.net/gimg/www.clublexus.com-vbulletin/2000x1504/2020_08_01_18_10_img_4852_74c284f265b5aed51922c4768f53607a6966ff1f.jpg)
Running the Niche M195 Methos Bronze with a 19*9 +38mm offset in the front and a 19*9.5 +38mm offset in the rear, very good fitment just wanting to drop the car but IDK if I should cause back is low with passengers. I also wanna go for a thicker tire in the back, rn its a 265/30/R19, wanna bump it up to a 40 to get some sidewall too
#2370
