Aftermarket Wheel Showcase - 3ISx Exclusive
#2431
For the front no one has put 10's on...and least no one on the forum, so you'd be the first I believe.
For the rear you would want something in the +40 or more offset if you're running a 10 inch rim.
If I recall correctly your current setup is 18x9.5 +38 square with a 5mm spacer added to the front.
If you go to 18x10 +35 that will push the rim/tire out in the rear approx. 9mm...it may cause some rubbing on the fender.
In the front it's gonna be really close to the steering knuckle. The 18x9.5 +38 without the spacer is pretty close already to the knuckle...consider the jump to 18x10 +35 will net you approx. 3mm inwards. It will be close but I think it will still clear by 1-2mm.
The outside of the front rim/wheel will stick out 4mm more than current...so not a huge amount. However it could be enough to cause rubbing on the fender on full lock turns or over big bumps.
I've been seeing x10 +40 for the rears. Hopefully 5 mm more isn't too crazy. I just don't want to be like the guy with a smashed rear fender in an earlier post. Haha.
#2432
The fronts would be the similar as 18x9.5 +40 in terms distance to the knuckle? I think there are a few people that ran those? Just haven't gotten the time yet to comb through this thread. I don't mind doing some minor fender pulling to make them fit.
For the rear there were some that reported rubbing when lowered on 19x9.5 +35, and some that didn't. It likely came down to tire size and brand.
With the 18x10 +35 I would anticipate some rubbing...but with the right 255/35/18 tire you might get lucky. You could also camber the rear wheels slightly if needed.
#2433
Any issues with tire stems from tpms hitting the brake calipers or rotors? I noticed the tire stems were more in the barrel of the wheel.
#2434
Hi everyone,
im picking up some xd9 and the specs are 18x9 +20 & 18x10 +38. TIres are 235-40-18 and 275-40-18. Im prob gonna switch to 225-40-18 front and 235-40-18 rear. Probs gonna roll fenders too.
do you think this will work on the 2017 is200t?
#2435
The front offset is a little low...for an 18x9 you'd want +30 offset.
For the rear, 18x10 +40 - +45 would fit without issue. Also for a 10 inch the minimum tire size would be a 255/35/18...the 235/40/18 is undersized for the rim, not to mention it will be a taller tire than the 225/40/18 on the front.
Also the rear fenders are factory rolled, there isn't anything left to roll on the rear...literally.
Alonzo3000 (04-08-21)
#2441
From your original +38 you want to go higher in offset, not lower.
Even 18x9.5 +25 is too low...if you got that in a +38 you'd be good.
#2442
#2443
I am looking to get verde axis v99 wheels on my is350 awd. Up front it will be 19x8.5 +32 with tire size 235/35/19 and rear will be 19x9.5 +38 with tire size 265/30/19. I am going to have stock ride height. Will this setup rub? These wheels have the tire stem more in the barrel too. Do you think it will clear the brakes?
#2444
