Aftermarket Wheel Showcase - 3ISx Exclusive
#2539
Received 1,738 Likes
@Rg1987 Was this the post you were referring to: https://www.clublexus.com/forums/is-...ml#post8777423
#2541
Plan on running RSR Downs whenever I get the new wheels. Not interested in going lower than that.
I came across this old video of a 3rd gen IS that appeared to be running this wheel staggered. I'm not sure; a) if the car was a 350 or 250, and b) what spec the car was running up front. I'm pretty sure this car was posted here before, but I can't seem to find it now.
#2542
I’m currently on RSR with stock wheel and tire set up for my 2016 IS300 AWD. I don’t want it to rub
#2543
Work VSXX
Finally got a hold of some Works...
19x9 +28 w/3mm spacer (to clear front brakes) 225/35/19. Perfect fitment no rubbing issues
rears are 19x10.5 +44. 265/30/19. Tires rub slightly on rears over bumps. I’m sure more negative camber will solve it. Or fender liner may just rub off. LOL. On RSR Downs RWD. 2015.
AchillezIS (07-27-21)
#2544
#2545
2014 is250 aggressive figment without camber kits
20x9 +35 in front 20x10.5 +42 in rear. Fromt rub like a mother ****er especially bottoming out but I pulled and cut the insides to where it turns a full 360 but if I pull up to a driveway I have to swerve and when it bottoms out I have to jimmy the steering wheel
#2546
What size tires are you running?
#2547
Titan7 Close-Up Shot
#2550
