Any help would be greatly appreciated, anyone know what is the widest wheel that can be fitted on a 19 x 9.5 inch wheel, 38 offset in the front of a 21+ IS350 on stock height and/or lowered?
looking through the wheel thread, not too many people mention tire sizes on the ‘21s and up. Thanks.
19" forged ray's wheels from a g35 square set of rears at 19 x 8.5 +35
Tires are a little too tall at 245/45 some rubbing full lock and rear fender contact under compression.
Okay, tried going through as much as i can on here but there's 180 pages sooooo. just want a little verification on wheel size.
2018 IS300 F sport RWD on RSR super downs
Front 19x8.5 +35 235/35/19
Rear 19x9.5 +42-45 265/30/19
Seemed like that seemed a typical sizing but wasn't sure with the superdowns whether being that low will be an issue. right now its not driven much but I could see myself swapping to Coilovers at some point.
Anyone running 19x8.5 +32 & 19x9.5 +33? Kinda skeptical about the rears and unsure what tires to run… I’m lowered on RSR Downs.
I feel like the rear offset is way too aggressive but I’m considering 225/35 in the front and 235/35 or 245/35 in the rears… how bad is it going to hit in the rears?
Here’s the wheel style and sadly they only come in that offset for the 19s.
I ran Rotiform LAS-R’s last year with 19x8.5+35 / 19x10+40 last year with 265/30 in the rears and it was fine but +33 idk …
I may have jumped the gun when buying my wheels but they are already shipped so I’ll cross that bridge when I get to it lmao.
I went with
F: 19x9 +32 w/ 235/35/19
R: 19x10 +35 w/ 275/30/19 and maybe a 5-10 spacer
They are Esr CR5 and Indy 500 tires
2018 is300 2.0t RWD
Does anyone foresee any issues I may run into? stock suspension for now but I plan on running down springs until I can buy a 3p air system
It’s been a while but any update on how this fitment turned out?
I’m trying to see if 19x9.5 +33 in the rears would be any issue and 19x8.5 +32 in the front
You should be okay with that. Will be tucked just enough for the rears to not rub. And that front fitment is very common on here as well. I ran 19x8.5 +35 and 19x10 +40 with those same tire sizes and lowered on RSR Downs with no rubbing.
2014 350 f-sport AWD:
Trying to go all square setup. Not sure below wheels will clear front brake calipers. Any advice or suggestions on tires as well would be much appreciated. thank you.
Any ideas for 19x8.5"+22 [F] 19x9.5" +34 [R] on a 2021+ AWD 350? Would love to keep the OEM 235/40R19 (F) 265/35R19 (R) tire sizes and potentially go to RSR Super Downs or Coilovers
Hey guys, new to the forum but I've been reading here since Sept when I got my 3IS. I Have a '19 IS300 F-Sport AWD and wanted to run a wheel spec and tire size combo past the experts here to see if I'm clear...
I'm looking to go with a squared set up of 18x9.5 ET35 on 255/35 Conti DWS-06+. The car will be lowered on RS-R Downs. I know I'll have to stay with a more narrow tire like the Conti over a beefier Michelin but other than that I think I should be good. Anyone know otherwise or see any pitfalls with the above specs?
Thanks!
Hello!
also recently joined. But have always used this site for research. Just curious if your setup worked? I’m wanting to go 20x9.5 et35 245-30-20’s. And I’am scared I May touch the control arm..
Hey all, wondering if these specs would fit on a 2020 AWD F sport?
19x8.5 +37 w/ 235/35 R19
19x9.5 +37 w/ 265/30 R19
Currently at stock ride height, but looking to lower soon.
