Aftermarket Wheel Showcase - 3ISx Exclusive
Old 06-08-23, 10:27 PM
  #2701
Aus10Cburn
1st Gear
Aus10Cburn's Avatar
Default Tire specs?
Originally Posted by chalun823
Varrstoen es1
19x8.5 +35
19x9.5 +40
Lowered on tein s techs, no fender mods at all
Love the look, was wondering what tires you had on, D/W/R
KObjective (06-10-23)
Old 06-18-23, 09:09 PM
  #2702
tilsim
1st Gear
tilsim's Avatar
Default Offset query
Hi, I have just got a 2017 IS200T and looking to move from 17 to 18s. Rims I like have 35 offset and the shopkeeper says for 35 I need to put hub adaptor since the OEM offset for the car is 45. Can someone please validate this? I don't want to change rims if it needs a hub adapter, I don't think adapters are safe, plus they result in quicker wearing off of the suspension.
Old 06-21-23, 10:11 AM
  #2703
Yubin
1st Gear
Yubin's Avatar
Rays Gramlights 57DR semi gloss black
5x114.3
18x9.5 +38
Michelin AS3+
245/45r18 square setup on Stock suspension
No rubbing or scrubbing
The following 3 users liked this post by Yubin:
GSiGuy (09-09-23), KObjective (07-22-23), tilsim (07-21-23)
Old 07-21-23, 10:29 AM
  #2704
Kitch32199
10th Gear
Kitch32199's Avatar
I know its an older post but why the spacer ?? did you need it to clear the front calipers ??
Old 07-21-23, 12:47 PM
  #2705
arentz07
drives cars
arentz07's Avatar
Received 3,723 Likes on 1,896 Posts
Who are you replying to? It might be good to quote-reply the post in the future so it is clearer.
Old 07-21-23, 01:28 PM
  #2706
Kitch32199
10th Gear
Kitch32199's Avatar
Yeah that was my fault. I actually messaged him.
Old 07-21-23, 05:17 PM
  #2707
Kitch32199
10th Gear
Kitch32199's Avatar
Originally Posted by delata
Another set of te’s
Older post but what wheels would these be ??
Old 07-21-23, 06:14 PM
  #2708
Racer00J
Racer00J's Avatar
Looks like the Volk Racing TE37SL. See similar below...
Volk te37
Old 07-22-23, 03:38 PM
  #2709
Kitch32199
10th Gear
Kitch32199's Avatar
Originally Posted by L3x14
Currently on 18x9.5 squared f1r wheels
Not sure if anyone can answer this question for me or not but I'll give it a shot. When blowing up the picture you can see he has the standard brake calipers in the front. My question is do you think this setup would clear the big brake calipers. Any info would be appreciated, thanks.
Old 07-25-23, 09:22 PM
  #2710
Racer00J
Racer00J's Avatar
^Highly doubtful. Those wheels have too much concave going on. Spokes would hit the larger brake calipers.
Kitch32199 (07-26-23)
Old 09-08-23, 08:19 AM
  #2711
GISguy
GISguy's Avatar
Springs: RSR Half-Down (on RWD)
Wheels: MRR GF10 18" x 8.5" +35
Front Spacers: 10mm (with extended ARP studs installed in hub)
Rear Spacers: 12mm (with extended ARP studs installed in hub)
Front Tires: Dunlop SP Sport Maxx 225/40/18 (stock)
Rear Tires: Dunlop SP Sport Maxx 255/35/18 (stock)
The following 6 users liked this post by GISguy:
arentz07 (09-08-23), Bechtold (09-09-23), cuellooo (09-14-23), KObjective (09-11-23), llO0DQLE (09-08-23), Oneops (05-31-24) and 1 others liked this post. (Show less...)
Old 09-09-23, 02:19 AM
  #2712
GSiGuy
GSiGuy's Avatar
5x114.3
18x9.5 +38
Michelin AS3+
Lovely! Is your IS an AWD or RWD? I'd like to run a similar setup on by 2017 IS200t (RWD) but have been advised the widest i can go in the front is 8.5 width.
Old 09-09-23, 11:15 PM
  #2713
OneManRB
3rd Gear
OneManRB's Avatar
Default Flush Fitment on Aftermarket Wheels
Hey guys new here on Club Lexus,
Looking for aftermarket wheels on my 2014 IS350 F Sport..
Looking at BBS SX Crystal Blacks or Work Kiwamis (after similar style to the OEM wheels without using spacers) - prefer BBS SX
What wheel setup should I go for that will give me a flush look, without scrubbing or rubbing?
Currently on:
RSR T1000 Downs
Pilot Sport 5s with Fronts: 225/40/R18 and Rears: 255/35/R18
Unsure if fenders are rolled etc.
Don’t mind square setup as long as tyres are not too stretched (want girth)
Thank you. No pics yet as it’s on stock wheels :/
Located in Melbourne Australia
Old 09-11-23, 07:29 PM
  #2714
mubsy85
mubsy85's Avatar
Hey Guys,
finally saved enough, read enough and have decided to choose the following for flush fitment
Work Wheels - Emotion ZR10
just wanted to double check with anyone else who has the same or similar specs first.
2018 is300 rwd f sport lowered on springs 1.0inch front 0.9 inch rear
= 19x8.5 +30 front 235/35/19 - 19x9.5 + 38 rear 265/30/19
Wheel nuts - M12 x 1.5
Hub rings - 73mm-60mm
let us know cheers!
Old 09-12-23, 12:10 AM
  #2715
OneManRB
3rd Gear
OneManRB's Avatar
Currently on:
RSR T1000 Downs
Currently looking at this BBS SX wheels:
Crystal Black 18" 8" 5x114.3 40 10013330 $619 AUD per wheel
How would this fit on my current setup?
Thanks guys
Quick Reply: Aftermarket Wheel Showcase - 3ISx Exclusive
