Aftermarket Wheel Showcase - 3ISx Exclusive
Old 10-24-23 | 09:21 AM
  #2731
cultivatedrice's Avatar
cultivatedrice
7th Gear
How's the change in tire wear?
Old 10-24-23 | 09:26 AM
  #2732
cuellooo's Avatar
cuellooo
not sure yet as I just had my rims put on a few months ago with the camber adjustment. Have them set at -2.5 degrees which isn't too extreme compared to stock spec, I would assume it would wear the inners a bit quicker but not too drastically. Next time my car is on a lift I'll take a closer look
Old 10-24-23 | 09:27 AM
  #2733
cultivatedrice
7th Gear
What's your wheel and tire setup?
Old 10-24-23 | 09:41 AM
  #2734
cuellooo's Avatar
cuellooo
Vossen HF-5
19x8.5 +30
19x9.5 +38
235/35R19
265/30R19
You can scroll up a bit to see pics, they're under post #2717
Old 10-24-23 | 10:35 AM
  #2735
cultivatedrice
7th Gear
I found your build list, nice!
Old 10-24-23 | 11:46 AM
  #2736
cuellooo's Avatar
cuellooo
Thank you! Hope it helps, cheers
Old 11-01-23 | 03:10 PM
  #2737
Jsole's Avatar
Jsole
1st Gear
Default 19x9.5 squared set up on 21 is350 rwd
What’s the most possible way to make this work im on stock suspension atm nothing’s been done just the exhaust thanks for the answer. Im trying to put 57dr bronze please need advice.
Old 11-05-23 | 04:14 PM
  #2738
Jonoschaff93's Avatar
Jonoschaff93
1st Gear
Default Will it work
2017 Lexus is 200t fully stock. Finally paid her off and figured id get a new wheel setup. Will these rotiforms work? How does the community feel about rotiform? Reliable? Heavy? One of my daily drivers so nothing to fancy.
Old 11-06-23 | 08:39 AM
  #2739
Meraki Autoworks's Avatar
Meraki Autoworks
Your #1 Lexus Vendor
We can get you setup with these. They're not forged wheels so definitely not the lightest or strongest but thats why the price is what it is.
-Josh
__________________
Your #1 Dealer for Aftermarket Performance Products
Orange County, CA
Text/Call: 213 394 2886
Jonoschaff93 (11-07-23)
Old 11-06-23 | 08:51 AM
  #2740
GSiGuy's Avatar
GSiGuy
Originally Posted by GISguy
Springs: RSR Half-Down (on RWD)
Wheels: MRR GF10 18" x 8.5" +35
Front Spacers: 10mm (with extended ARP studs installed in hub)
Rear Spacers: 12mm (with extended ARP studs installed in hub)
Front Tires: Dunlop SP Sport Maxx 225/40/18 (stock)
Rear Tires: Dunlop SP Sport Maxx 255/35/18 (stock)
Lovely! Experiencing any rubbing? I have same spec tyres and 18x8.5 front 18x9.5 rears. Et38 all round. I'm wondering if half downs would rub...
Old 11-09-23 | 08:48 AM
  #2741
wweerr123's Avatar
wweerr123
Guys, I'm looking at 18x9.5 with 35mm offset for the rear for 2021+ IS. Will this cause rubbing or anything if everything else is stock?
Old 11-09-23 | 09:07 AM
  #2742
cp2's Avatar
cp2
you should be fine. what width/series are you getting for the front? i wouldn't go more than 235/30 maybe 35 for the front to be safe. rears you're good.
Old 11-09-23 | 10:07 AM
  #2743
CT3IS's Avatar
CT3IS
Rotiforms arent the best but theyre not the worst. They are kinda heavy compared to other brands as well as more susceptible to cracks or bends. you can also downsize to 18s to go 18x9.5+35 square since 8.5+35 up front is a little bit weak.
Old 11-09-23 | 10:12 AM
  #2744
CT3IS's Avatar
CT3IS
Won't this be too skinny for a 21+? I thought this tire size was more suited for 19s on the newer ones.
Old 11-09-23 | 04:11 PM
  #2745
wweerr123's Avatar
wweerr123
I'm thinking about 18x8.5 for the front, perhaps 35mm offset.
Quick Reply: Aftermarket Wheel Showcase - 3ISx Exclusive
