I'm thinking about getting a set of Work Emotion CR Kiwami wheels in matte bronze. If I were to get them with the following specs, would there be any chance of rubbing?
I would say you should have no problem... I have the same wheels in GTS and I have a 275 rear tire and it just barely rubs in the back.... Front has no problem what so ever...
Another thing I'm considering is to go with a square setup, with the 19x9.5 +38 deep concave all around. Would a 255/30/19 all around be okay without rubbing with those wheel specs?
Too aggressive and will rub IMO.
I'm on 19 x 8.5 + 38 with 235/35/19s at front , RSR Downs - and no rubbing but it's cutting it close. If you want square, max I'd go is 245/35/19s on the 8.5 wide +38 rim would work but double check this thread for those who have this similar size at front. I'd also get a more rounded shoulder tire just in case for the extra 1-2 mm clearance.
Got my alignment done yesterday 4 weeks after my new wheels and RSR downs had plenty of time to settle.
Toe was noticeably out and after adjustment, car feels lighter with less drag. I didn't expect that much of a difference but was a pleasant surprise. Pricey but worth every penny!
170 bucks for an alignment?! Do they work with the golden tools?
^^^ A reputable 3rd party in my area for an AWD vehicle will be around 100$ but I've also heard of issues with some places unable to properly align this car. So get it done right the first time.
