Aftermarket Wheel Showcase - 3ISx Exclusive
Old 03-29-16, 03:55 PM
  #511
highrevz
highrevz's Avatar
Originally Posted by Answer
won't fit. They will touch (or almost) the upper control arm.
Ooh great. Well what sizes would u suggest that would look more aggressive than stock without rubbing or rolling fenders for TE37s??
Old 03-29-16, 04:43 PM
  #512
Answer
Answer's Avatar
18x9 +30/+40
18x8.5 +30/+40
depending on the tire, they should fit.
Check out willtheyfit.com to find out more!
Old 03-29-16, 05:02 PM
  #513
highrevz
highrevz's Avatar
18x9 +30/+40
18x8.5 +30/+40
The tire size are 235/40/18 all around
Old 04-01-16, 10:21 AM
  #514
JTLexIS
JTLexIS's Avatar
-RSR Down Springs
-K3 Projekt Wheels
20x9 ET38 (245/30/20) Front,
20x10.5 ET42 Rear (255/30/20)
Old 04-01-16, 01:49 PM
  #515
Answer
Answer's Avatar
Originally Posted by JTLexIS
-RSR Down Springs
-K3 Projekt Wheels
Very nice!
Any rubbing up front? Looking for a set of 18x9 +38 and was wondering!
Old 04-01-16, 01:56 PM
  #516
Javahersaz
Javahersaz's Avatar
Default Help
Going to buy workT7R emotion series 19"
And allready lowered with tein s tech lowering springs, and want to know which spec is better and want no rubbing at all,
19" 8.5 +35 f
19" 9.5 +36 r
And also tire size help needed 😅
Old 04-01-16, 02:40 PM
  #517
JTLexIS
JTLexIS's Avatar
Very nice!
Very slight rubbing in the front at full turn, minimal. I actually had 225s up front at first, but switched to 245s because with these wheels it was waaay too much of a stretch for my liking. And it seems to fill the wheel gap better.
I think you'll be fine with 18x9 +38. I believe that is close to stock.
Old 04-01-16, 02:49 PM
  #518
JTLexIS
JTLexIS's Avatar
19" 8.5 +35 f
19" 9.5 +36 r
I ran this set up with RSR Down springs. No issues at all.
Front 19x8.5 +38mm 225/35/19
Rear 19x9.5 +40mm 255/30/19
You should be fine with +35 and +36
Old 04-01-16, 03:09 PM
  #519
Answer
Answer's Avatar
Made a typo, the ones I'm looking at are +40, not much difference though. I can live with some slight inner fender rub at full lock.
9 +40 is actually 8mm closer to the suspension and poke 18mm more.
Old 04-01-16, 09:11 PM
  #520
DEMONX
DEMONX's Avatar
Any suggestion of this set up 18x9.5 +15 offset? Is that too aggressive ?
Old 04-01-16, 10:14 PM
  #521
Javahersaz
Javahersaz's Avatar
Thanks for quick replay
And want to know which tire size is better, for filling the gap,
I think about 235/35/19 front 265/30/19 rear, any rubbing?
How about going more concave?
+30 front
+12 rear?
Work wheels t7r 1pc specs
Old 04-02-16, 01:49 AM
  #522
Meraki Autoworks
Your #1 Lexus Vendor
Meraki Autoworks's Avatar
Anyone interested in buying some Vossen X Works edition wheels? :P
-Josh
__________________
Your #1 Dealer for Aftermarket Performance Products
Orange County, CA
Text/Call: 213 394 2886
Old 04-04-16, 06:52 AM
  #523
Sphinx007
Sphinx007's Avatar
+30 front
+12 rear?
LOL! Those specs won't fit...period. We aren't running nissan Z.....with the 3is your range of offsets are limited unless you go air
Old 04-04-16, 07:07 AM
  #524
FullAtomic
FullAtomic's Avatar
+30 front
+12 rear?
Yeah man, you're crazy if you want to go +30 or +12
You MIGHT be able to pull 30 in the front.
+12 in the rear is a good waste of money.
I've never heard of anyone running 9.5" and have less of an offset than 35 (slammed), you Just can't do it, sorry bud. Lexus has no room.
Old 04-04-16, 07:40 AM
  #525
DEMONX
DEMONX's Avatar
I was just looking at a post for sale for some wheels. They are 18x9.5 +35 off set
And 18x10.5 +12 offset. Any idea if could work?
Quick Reply: Aftermarket Wheel Showcase - 3ISx Exclusive
