Aftermarket Wheel Showcase - 3ISx Exclusive
Old 04-25-16, 06:50 AM
  #586
Sphinx007
Sphinx007's Avatar
got my calipers painted with the new wheels
Old 04-25-16, 03:23 PM
  #587
Ray20213
Ray20213's Avatar
Default wow
looks really nice!...great job
Old 04-25-16, 11:05 PM
  #588
atomic250
atomic250's Avatar
Originally Posted by steveo55
Just got some vossen's
Front 20x9 Rear 20x10.5
Tires 235/30r20 fromt 255/30r20 rear
Nice VLE-1!!! I just purchased a set and trying to figure out what tires to get. How's the ride quality and is there any rubbing with your suspension? What tire brand are you using?
I'm planning on installing 235/30R20 Front and either 265/30R20 or 275/30R20 in the Rear.
Old 04-26-16, 01:36 PM
  #589
DEMIK
DEMIK's Avatar
Stock RCF wheels and tires
(Front 19x9 + 50 offset with a 255/35/19 Michelin PSS Tire
Rear 19x10 +41 offset with a 275/35/19 Michelin PSS Tire)
Stock height
15mm spacer in front.
Very slight rub in rear over bumps.
Old 04-26-16, 04:03 PM
  #590
tank505
tank505's Avatar
Default What kind of calipers of that I am looking for a set of them
What kid of caliper is that ? Looking for that
Old 04-27-16, 06:43 AM
  #591
Sphinx007
Sphinx007's Avatar
They are the oem F sport calipers lol
Old 04-27-16, 08:34 AM
  #592
steveo55
steveo55's Avatar
Aftermarket Wheel Showcase - 3ISx Exclusive-brys8zy_fa7660f0e1217c6f023cce28ec3787e54d549035.jpg
Ive had an adventure trying to make these work. Started off with RSR downs got rubbing. I rolled all 4 fenders still rubbed. I purchased spc rear camber arms had to run negative 4 degrees so it wouldnt rub. I wore my rear tires in 4 thousand miles. First set of tires were falkens. Second set are now toyo proxes. So i ended up swapping out my down springs for RSR half springs. Still have a bit of rubbing going to have to rol fender in rear tad bit more.
Old 04-27-16, 09:49 AM
  #593
dnasians
dnasians's Avatar
sounds like you're offsets for your rear wheels are too aggressive.
and i noticed you're running 255/30/20 in the back. you can try to lower the side wall a bit by running a 25 series (255/25/20)
Old 04-27-16, 02:30 PM
  #594
atomic250
atomic250's Avatar
Did you have any rubbing in the front? I knew the RS-R Down was going to be an issue so that's why I went with the Half Down. How's the ride quality with 20 inch wheels? I'm currently waiting for my tires to arrive.
Old 04-28-16, 06:42 PM
  #595
sklzwpillz
sklzwpillz's Avatar
My summer setup
Work Zeast ST1
SO. DOPE.
Are those the brushed aluminum or trans gray polish?
Old 04-29-16, 08:39 AM
  #596
Sphinx007
Sphinx007's Avatar
Originally Posted by sklzwpillz
SO. DOPE.
Thanks! They are trans grey polish They look silver under bright light and fades toward grey when there is less light
Old 04-30-16, 10:18 AM
  #597
gusgus91
gusgus91's Avatar
18x9.5 +7 Front
18x10.5 +30 Rear
Old 04-30-16, 10:27 AM
  #598
Imprezario
Imprezario's Avatar
Originally Posted by gusgus91
18x9.5 +7 Front
18x10.5 +30 Rear
Meisters?!
Old 04-30-16, 10:46 AM
  #599
ALtin107
ALtin107's Avatar
I like the yellow calipers with white exterior
Old 04-30-16, 12:28 PM
  #600
gusgus91
gusgus91's Avatar
Originally Posted by Imprezario
Meisters?!
Yep! I hadn't seen a 3is with meisters yet so I wanted to do it! So I did it!...Then ended up selling my car. Thinking of putting the meisters on my IS300 or possibly selling them.
Quick Reply: Aftermarket Wheel Showcase - 3ISx Exclusive
