Avant Garde F421
20x9 front 20x10.5 rear both offset +35
Tires are 245/35 front and rear are 275/30. Rubs like crazy. Thinking of going 225/30 front 255/30 rear, will that work?
Stock springs. Planing on lowering it with the Rsr down springs.
Have a shop pull/roll rear fenders and you should be good.
255 is definitely the largest you can go in the rear without any rubbing issues on RSR downs.... Looks good but definitely need to lower it !!!
haha he will rub no matter what tire given his rear offset is +20 lol.....with RSR downs you can max go +42 with a 9.5" wheel without rubbing ...good luck!
AG m652 in brushed electron blue
19x8.5 +20 225/35/19
19x9.5 +38 255/30/19
Lowered on RSR super downs and 20mmm SAGE rca spacer
slight rub in the front over bumps nothing in the rear
18x9.5 ET35 all around 265/35/18 Bridgeston RE71r all around
Nice car! I'm going to be running a similar wheel setup like yours except 18x8 +40 front and 18x9.5 +40 rear. Is your car lowered with springs or coilovers and how much is the drop? Thanks!
