Aftermarket Wheel Showcase - 3ISx Exclusive
Old 11-27-14, 08:55 PM
  #61
wiliu0
wiliu0's Avatar
I'm planning to go 235/35/19 in front and 265/30/19 in the rear. Since you say the front won't rub will the rear have any clearance/rubbing issue? If It does how about 255/30? Thanks
Old 11-28-14, 06:42 AM
  #62
NVMarkus
NVMarkus's Avatar
Depends on the offset of the wheels...but more than likely no...
kaleo211 (03-08-20)
Old 11-28-14, 10:16 AM
  #63
wiliu0
wiliu0's Avatar
19x9.5 +40 in the rear .
Old 11-28-14, 11:46 PM
  #64
criticalgt
criticalgt's Avatar
That's what I've been trying to figure out myself...there have been people running those specs but I have not heard anyone rubbing. For instance look at the blue one in the link below. That rear looks perfect.
https://www.clublexus.com/forums/is-...t-now-131.html
Those specs would be like running 25mm spacers front and back on your car...
Front
Rear
socialdx (01-01-19)
Old 12-04-14, 05:42 PM
  #65
dizlex
dizlex's Avatar
Originally Posted by juvi22003
My second set
Work Emotion Kiwami
19x9.5+38 225 35 19
19x10.5+32 235 35 19
Such skinny tires on such wide wheels!
Old 12-07-14, 01:49 PM
  #66
aznghetto
aznghetto's Avatar
I was wondering if I ran 18x8.5 +25 all around with stock tires if it would fit? and would have any rubbing issues? even lowered
also i want a flush look so i dont know if it will be sunk in or not
Thanks
Old 12-08-14, 07:38 AM
  #67
b00st3
b00st3's Avatar
I didnt get any response over in the tire/wheel section, so i'm hoping someone here may be able to help!
I have a set of 19x9 +35 Fronts and 19x10 +44 Rears coming in. I was thinking i should run a 235/35 and a 275/30. Should I rub with this setup? I don't want to have to do any fender mods and I want to have a bit of lip protection.
Thanks!
Old 12-08-14, 01:31 PM
  #68
NVMarkus
NVMarkus's Avatar
Originally Posted by threefiddy
spoiler! what spoiler is that?!?!?
Not sure if I answered this..
JM Auto and 168 motoring
It is a Seibon rear spoiler and diffuser
Old 12-09-14, 09:26 AM
  #69
juvi22003
juvi22003's Avatar
Not really they just sound skinny...
Old 12-09-14, 05:08 PM
  #70
NVMarkus
NVMarkus's Avatar
Thanks!
Fronts are good for sure, I think you should also be good on the rears...
I barely tap my fender when at freeway speed and hit a big bump, and I have 38 offset on the rear...
good luck!!
Old 12-10-14, 01:16 PM
  #71
PAPI007
PAPI007's Avatar
Hey guys, I purchased some 19+8.5-35mm wheels--tires 235/35/19 for the front and for the rear 19+9.5-40mm wheels--tires 255/30/19. The wheels are concave. I did'nt even check for fitment, I trusted that the guys knew what they were talking about. Before I open them can anyone confirm that these wheels will fit? The rear looks to big but it could be my imagination. My car is also lowered on RS*R Downs. Please help me!
Old 12-10-14, 03:30 PM
  #72
lexi90
lexi90's Avatar
The 255-30/19 will be small for those rims. It will look stretched. Anyways, others have done it here and it's not as bad!
Old 12-10-14, 03:32 PM
  #73
PAPI007
PAPI007's Avatar
What size should I have went with?
Old 12-10-14, 04:10 PM
  #74
b00st3
b00st3's Avatar
good luck!!
Thanks for the assistance!
Old 12-10-14, 06:53 PM
  #75
asapcolin
asapcolin's Avatar
Vossen CV7
19x10 +38
225/35/19
RSR Super Downs
No Rubbing
Alonzo3000 (04-12-20)
Quick Reply: Aftermarket Wheel Showcase - 3ISx Exclusive
