Aftermarket Wheel Showcase - 3ISx Exclusive
#782
No rubbing with this setup. I tested by going over bumps, dips, and bad roads and all 4 tires cleared. If you decide to go with Down Springs instead of Half Down then it's better to go with 255 in the rear. I think if Niche made these with +42 or +45 offset it would be perfect. I chose Half Down to keep my normal driving style. The only thing I have to worry about is not hitting the curb.
mjh09e (12-14-16)
#785
#788
Does anyone ride on 19x9.5 +35 all around?? If so what tire size do you recommend and will rsr super downs work or should i look into rsr down? Dont really want wheel gap.
thanks for any inputs everyone
#789
It looks great but I don't know if it just the pictures or me but you can barely see the detail on the rims. It looks like the black kind of blended everything together with the tires.
Sorry I'm trying to find the perfect wheels for my wrapped IS and it doesn't help that I'm really picky. But the wheels do really look good
#790
#792
No worries, and definitely no need to apologize! I think it's a combination of poor lighting and the fact that they are black wheels. Either way, my advice to you is don't rush your decision unless you're the type to swap out wheels pretty quickly. There's so many options out there. I've actually been thinking about removing the black roof wrap to see how it changes the look of the car, but I'm worried that I'll end up getting it wrapped again if I don't like it...
#793
Finally put my AG M610s on the car...before I mounted them I decided to check weight savings since these are lightweight rotary forged wheels. Found there to be a significant weight savings with this wheel/tire combo. Could be psychological, but steering feels lighter (not sure if that's good to me yet - may just need to get used to it). I know when I went with heavy 20s on my G35, steering, MPG and acceleration took a hit. Switching to forged Rays improved on all of these. Unsprung weight is bad.
#795
How much was the set? The rears fit well? I was thinking of doing the same down the road. Can you post more pics? Side view? I want to check proportions. Classy and high end!!
