Aftermarket Wheel Showcase - 3ISx Exclusive
#1006
Received 1,735 Likes
You will see tire sizes and offset is discussed. Basically +35 front and +40 rear.
#1008
#1012
245/30 has a shorter sidewall so it may not be able to stretch as much. I ran a set of 235/35/20 Nitto on 20x9.5 Konigs, and that was the widest wheel width Nitto recommended for that tire.
Now can you physically do it? Probably, but that doesn't mean it is safe to drive on especially at high speeds.
#1015
hi all currently running 19" 235/35 & 265/30 on RSR downs. Looking into getting TE37SL's. Will 19x9.5 +35 & 19x10.5 +35 have any fitment issues? Not looking to do any fender work. Thanks!
#1016
#1017
Wheel fitment question.
Will a 20x9 et 20 fit the front of a 2014 fsport and the rear on 20x10 et 30 ? I plan on going air and want to confirm if any major work will need to be done. Or if I need to stick to et36 up front and et40 in the rear?
#1018
19x9.5 +45, 265/30/19 doesn't rub no fender work on RSR Half Downs
19x10 +35, 245/35/19 rubs, no fender work on RSR Half Downs
19vx10.5 +43, 245/35/19 doesn't rub, no fender work still on RSR Half Downs
