Aftermarket Wheel Showcase - 3ISx Exclusive
#1111
davyjordi, I have the same wheels but have Swift springs and when I switched from the stock F-sport 18"s to F sport forged 19"s the car sat slightly higher than before. Tire brand, size and diameter will sometimes do that especially if the tires are new and has fresh tread vs your used tires.
#1112
I thought you mention you were going with coilovers?
#1113
edit: i rebought them. hah.
#1114
Received 1,737 Likes
#1116
![Wink](https://www.clublexus.com/forums/images/icons/icon12.gif)
lol... command decision!
My 1st time going with coilovers as a daily driver so I hope the benefit is to be able to adjust them to my liking than be stuck with a one dimensional spring and shock rates for all my driving needs. The factory suspension is a well thought out design and meant to please the larger mid sport class. The factory ride quality is more road compliant than probably any aftermarket spring shock set up. When you go aftermarket mods you're basically re-desigining the car to a defined purpose. Some mods can't co-exist without a trade off somewhere else.
Hey at the end of the day it's whatever makes your driving experience enjoyable!
#1117
Hey at the end of the day it's whatever makes your driving experience enjoyable!![Big Grin](https://www.clublexus.com/forums/images/smilies/biggrin.gif)
Anyhow, I also bought low-profile tires that because I think the sidewall of the current tires is helping to provide for an awkward stance. Some CL members have also made comments on this when asked what went wrong -- 4x4 status.
Hopefully all will be said and done by next weekend. Fingers crossed.
Need4Speed (08-15-17)
The following 2 users liked this post by jmull3r:
Need4Speed (08-16-17),
Slplknight (09-06-17)
#1122
Guys, I have been through pages and pages of this thread and I'm still a dumba__.lol Trying to figure out rim size that will look good on my car is difficult. I live in a town where the roads are super messed up so having enough tire on the ground is a must. Considering sticking with a set of 18" rims but the offset confuses me. Specs are : 18x8/18x9 5x114.3 35/32. No idea what that all means reguarding offset. I know stock our offset is I think 45 front and 50 rear. So with this being 35 front and 32 rear will they sit somewhat flush with fenders or am I lost in the matter? I know a lot of you guys have done rims and have the info so I appreciate the help. I'm running stock rims and tires now with 20mm spacers to give it the look I want. Just don't know enough about rims to tell if this would give me the same look so I can remove the spacers.
#1123
Check out willtheyfit.com and play around with some numbers.
Is200tnc (08-20-17)
#1124
Either increasing the front to an 8.5 width or reducing the offset to around 30 will be it closer to flush.
Is200tnc (08-20-17)
#1125
