Aftermarket Wheel Showcase - 3ISx Exclusive
#1231
Received 1,738 Likes
Are you going square setup or staggered?
#1232
#1233
The rear with the 275 will likely be ok as the usual concern is rubbing on the fender if the vehicle is lowered, but you want keep the vehicle at stock height, so you should be ok.
Just be mindful if you load the vehicle up with passengers and cargo.
If you decide to lower the vehicle after, you may run into issues.
To give yourself that little extra clearance on the rear, you could go with a 265...and finding out the tire Tread Width may help too.
From manufacturer to manufacturer the Tread Width will vary for the same size tire. Tirerack.com is a good place to see tire Specs.
As per my signature below, I also have 20's on RSR Downs, with a square setup 235/30/20 +35 with 8.5 width. The front rub at full lock...no issues in the rear.
sdqqbb (01-31-18)
#1234
The 245 on the front will likely rub when the wheel is at full lock on the inner fender...but not a big deal, as how often and fast do you drive at full lock.
#1235
I guess the cons would be the staggered setup looks slightly better. Mainly from the rear
#1237
Depending on the specs and tires, handling could also be improved, but i'm not tracking the car, so as a Daily Driver (with flashes of spirited driving lol) it handles fine for me.
The biggest Con is the staggered fitment looks a lot better with the right wheels.
#1238
You wouldn't know if your car "understeered" or "oversteered" unless you exceed adhesion limits aka speeding around a corner skidding. And on a slammed/stanced car, I don't really see that as a reality.
A square setup may result in more neutral handling, however at the cost of reduced steering feel/feedback in the front as you are now adding more weight/mass vs the stock smaller size.
#1239
Hello folks...
Another one of those will it fit questions...
my friend is selling his TE37’s square set up:
19x9.5 plus 22 offsets
i am lowered on rsr downs...will this fit ok? I cnt test fit as he lives a full hour away so i wanted to either pick them up if it fits thanks folks
#1240
Hello folks...
#1242
Consider a 19X8.5 +35 is almost flush with the fender on the front, so if you went to a 19X9.5 +22, that would basically move the other edge of the wheel outwards an inch...so now it can hit the fender, or fender liner at the very least.
On the rear a 19X9.5 +38 is almost flush once again...so going to a +22 with move it a little more than half an inch outwards...combine that with the tire and it will rub on the fender.
RU4Rhyl (02-02-18)
#1243
Mainly the offset. Others have run 9.5 on the front...I wouldn't say it's common, but others have done it.
#1244
So overall the tire would be 2 inches narrower than the rim. Personally I wouldn't recommend it, especially if the roads around you are not the greatest...that's just a recipe for a blowout.
Even the back the tire would be over an inch narrower that the rim...once again, my personal opinion, it's not worth the risk.
RU4Rhyl (02-02-18)
