Had my Vossen Work since November of last year! Finally started to install them!
Specs:
F 19x8.5 +32
R 19x10 +48
Hankook 235/35/19 Front / 275/30/19 Rear
No rubbing on the rear! Still have to finish front! I expect no rubbing issues!
Looks great! I was tempted to try 275-30 on my CVTs(19x10 +42) also on downs but I figured I’d rub. Maybe the extra 6mm makes all the difference
Thank you bro Your car looks good on the CVT as well! I'm loving the fact that I was able to run 275-30 rather than 265-30! I wanted to go as wider as possible! Btw, I am also on Downs! No rubbing in the rear yet! Still have to finish installing them and taking it for a ride with people on the back seat...
Keep me posted on this. I will switch to 275s when my tires wear out. I rarely have people in the back so I’m in the same boat as you.
Hey guys, can someone tell me if I would have a a fitment issue with this set up? I just bought cr Kai 19x8.5 +35 for the fronts and 19x9. 5 +38 and im planning to run 235/35/19 in the front and 265/30/19 in the rear. Thank you!
Thanks!!! I saw in a few posts saying the fronts may not clear the breaks so i was concerned. I'm new to fitment on wheels so would my spec be flush with my fender?
It should be flush...ultimately wheel design dictates what final appearance looks like.
Typically, 8.5 +35 on the front should clear the bigger brakes found on the 200t, 300, 350.
It would take a uniquely designed wheel to not clear.
If the offset was larger, say +40 or +45, that would be a different story.
I I bought Stance SF01 in 8.5 +35 and they didn’t clear my brakes without a 3mm spacer. I ended up returning the +35 fronts and swapped them for +30 and its good now
