Aftermarket Wheel Showcase - 3ISx Exclusive
VisualEcho (11-04-18)
#1311
Quick question. I have a 2015 AWD IS 350 F Sport. I am trying to run a 18 inch square tire setup on stock height with the rims linked below. Which size rim 8 with 40 offset or 8.5 with 35 offset should I get with what size tire for a square setup? Apologies for the noob question I don't know too much about wheel specs.
https://www.tirerack.com/wheels/Whee...utoModClar=AWD
if your car is silver, go with gun metal.
don't go black
#1314
New here, I have a 15is3fs awd looking for a concave wheel in the rear. I ordered rsr downs and I don’t want it to rub anywhere at all, I don’t wanna do fender mods or roll lips. From what I see, some have had problems with 19x8.5 38et clearing the bigger calipers. Is 32et too aggressive on full turns with 235/35s? In the rears seems like people are rubbing with 19x9.5 et38 and 265/30’s? I want to be able to have the car full without worrying about rubbing issues. Any help is appreciated
Some sick a$$ cars here!
#1315
#1317
#1319
hi! I'm getting new wheels soon and have some questions about fitment. Looking to get a set of Kiwamis in 18x8.5 + 30 and 18x9.5 +40. I know the rears should clear, but what about the fronts? I'm lowered a bit on coiliovers with at least a 2 finger gap.
Also, should I go with 255/40/18 on the rear or 265/35/18?
Thanks in advance!
Thanks in advance!
#1320
Hi guys!
I am currently lowered on RSR Down springs and planning to go with a square setup 19x10 +35 BUT I am not sure about this offset. I want to avoid any rubbing but just wondering if this is possible.
I heard somewhere that +38 is ideal offset for square setup?
And how much camber would there be with these wheels. Ideally i want to be as close to factory specs as possible.
Also, what is the largest tire size I would be able to fit? And is it beneficial to have larger tires in the rears?
2015 IS350 F Sport
Thanks!
2015 IS350 F Sport
Thanks!
