Aftermarket Wheel Showcase - 3ISx Exclusive
#1396
I haven't personally on the RSR yet but my buddy had and he had no problems with them.
#1397
#1404
I am looking to get Niche Targa wheels F=19x8.5 +35 R=19x9.5 +35, lowered on RSR downs. Im a bit iffy about the offset in the rear. Tires i am thinking to run F= 235/35 R= 265/30. Can this setup work?
#1405
2014 IS250 Fsport. Ready to order today but trigger shy due to any possible issues with rubbing. Want to go as aggressive as possible, but not rub.
Does anyone know if I will have rubbing issues with the following set-up?
RSR Downs
Front: 19 X 8.5 +35 (225-35ZR19)
Rear: 19 X 9.5 +35 (265-30ZR19)
Niche Verona & Toyo Proxes
Thanks!!
RSR Downs
Thanks!!
#1407
Rear might be an issue. Maybe a 255/30/19 and a little bit of praying...if you're religious lol
#1408
So do you suggest i go with RSR half downs with the wheel setup I want? the reason i ask is because that wheel unfortunately is only made with the rear in +35 offset. I know the front fitment will work.
#1409
Running works cr kais candy red, 19x8.5 +35 in the front and 19x9.5 +38 in the rear wrapped with yokohama advan sports 235/35/19 and 265/30/19. A little rubbing in the front when doing a full lock and wondering if I dropped the car with rsr super downs would there be any rubbing issues?
#1410
If you already have the Downs installed, then I say give it a try first and see what happens. Even if it rubs, it should be minimal, so it will give you a chance to explore options.
You could raise the vehicle on Half Downs, or switch to a 255/30/19, or install SPC camber arms and camber in the rear just enough to clear.
simon876 (07-11-18)
