Turn Signal Relay Location
Hey guys & gals,
Does anyone know where the turn signal relay is located? I want to change my stock turn signals to LED. However, I don't want to use those "load resistors" or "cancelers". iJDMtoy sells an LED relay for the 14' IS (confirmed). After looking through the manual and at all 3 fuse/relay locations I can't locate it. Can anyone help? Much appreciated!
I tried all that.. It was mentioned on the GS Section too but on the newer models you can't just change out the signal relay. Ended up getting these bulbs and there's no hyperflash
http://store.ijdmtoy.com/No-Hyper-Fl...s-p/20-001.htm
I bought those for my front turn signals. However I was somewhat irritated that they came with "cancelers". Have you installed these in the back? I've briefly removed the tail lights and it looked super tight back there and I don't know where to put the canceler box.
You need to install the canceler/resistor module at an angle so that the tail light assembly clears it above. 3M VHB or another double sided adhesive tape will do. With the added wiring, it's a little tricky to get the tail light to clip back in properly without crushing things but it's doable. Just have a microfiber cloth with you so that you don't damage your paint as you do the installation while the light is hanging.
