What is type A,B...E?
Hi all.
I was reviewing my IS250 owner manual to see the tire sizes it rexommands. In the tire and wheel section. It said something like type A,B...E. What does these types mean?
Thanks
Thanks
Thanks for the quick reply. What is offset ? I searched on google, it said it the size of the rim, is that correct? I though only the 225/45R17 rim would fit the 225/45R17 tire isn't it?
The pursuit of F
Offset is the distance (+ or - ) from the center line of the rim. This value determines how far "in" or "out" the rim is within the fender.
Tires and wheels can be a little tricky to understand if you are new to this. See the following to help:
http://www.goodyearautoservice.com/c...eName=TireSize
Thank you so much for all the information. I am new to these, please bear with me and all the questions.
I was reading the user manual, it mentioned that the wheel size should be 17x71/2J. All i get from this is 17" wheel, not too sure what the other numbers are and Google aren't very helpful on this matter, but i don; think it is the offset number.
Can you please let me know what size of the wheel i should get for the 225/45R17 tires and what's the offset, or how can i get the information?
Thanks in advance
17x71/2J is read 17 x 7.5 J. It means a 17" wheel with a 7.5" wheel width. The "J" represents the shape of the wheel where the tire bead seats.
On a 7.5" wheel, 225mm tire is fine. I wouldn't go larger than 235 though.
But most importantly, as others have mentioned, the offset has to be correct or the wheel will not fit; either too much poke or too close to the shocks/struts.
The offset is stamped on the inside of the wheel, on or near the hub or the spoke. Look for the wheel size and then the number next to or under it. For example a 17x7.5J41 or 17x7.5JET41 wheel has a +41 offset.
From the OEM offset number, you can use the calculator below to determine the offset for new wheels. The calculator will show you how much "in" or "out" the new offset will cause.
http://www.1010tires.com/Tools/Wheel-Offset-Calculator
Here's my old ride to help show what different offsets look like. The fronts' are 17x7.5J et41 and the rears' are 17x9J et8.
Generally speaking, the smaller the offset is, the more concave or deeper the wheel well.
IS350DMAR
10-17-13 06:35 PM
PR FIEBRU
Wheels, Tires & Brakes Forum
03-12-09 04:54 PM
Scott1258
01-03-06 09:42 AM
