Hit the dyno today
Old 01-03-15, 11:38 AM
akshunj
akshunj's Avatar
Default Hit the dyno today
They had an open dyno day near me 2 pulls so I figured WTH why not. Stock 2014 IS350 AWD made 251hp to the wheels.
I'll try to get the sheet scanned in. I'm having trouble with my scanner.
Old 01-03-15, 05:29 PM
JCWong
JCWong's Avatar
mind if I ask what dyno was it on?
Old 01-03-15, 07:03 PM
akshunj
akshunj's Avatar
Mustang dyno
Old 01-03-15, 07:12 PM
4TehNguyen
4TehNguyen's Avatar
mustang dynos read a little lower
Old 01-03-15, 07:27 PM
joeis3fsp
joeis3fsp's Avatar
Good to know, are you planning any performance Mods. Thanks for sharing.
Old 01-03-15, 07:28 PM
akshunj
akshunj's Avatar
Yeah it's cool the car did about what I expected. They didn't have the wideband hooked up so I didn't get any AF ratios. There's some rippling in the power graph, so I suspect the factory grounds could use some improvement. I'll probably go back for some more pulls with additional data points.
Old 01-03-15, 10:16 PM
sirwawa
sirwawa's Avatar
is that good or bad?
anything to compare it with?
Old 01-04-15, 09:16 AM
4TehNguyen
4TehNguyen's Avatar
other dynos should read 270ish, mustangs read lower so 251 sounds in line
Old 01-04-15, 09:27 AM
akshunj
akshunj's Avatar
Well there was a 2014 370z that ran after me. He put down 270. I think those are rated 335 to the rear wheels?
Old 01-04-15, 09:47 AM
akshunj
akshunj's Avatar
Weighing options for now. I'm not looking for huge gains, but 50 to 100 would be nice.
I don't have any experience with direct injection used on these motors. I'm not sure if we can just install bigger injectors like port injection motors. This is my first car with CAN. All my other cars were OBD1, 2 or carburated, so I need some updated tuning tools.
I want to see the AF ratios to look at what the stock ECU is doing. The horsepower falls off a bit as you get close to redline. I've seen on other toyotas I owned that this is due to the car running a little rich on the factory tune in open loop.
Old 01-04-15, 09:51 AM
akshunj
akshunj's Avatar
Old 01-04-15, 09:53 AM
akshunj
akshunj's Avatar
akshunj
akshunj's Avatar
Old 01-04-15, 10:03 AM
Loe
Loe's Avatar
It's about right considering it's an AWD model and a 17% driveline loss.
Old 01-04-15, 10:10 AM
akshunj
akshunj's Avatar
My scanner is giving me fits, here's a blurry scan:
Quick Reply: Hit the dyno today
