Downshift clunk when coming to a stop? IS350
If you have Aftermarket Exhaust, that's the Back fire POP when car downshift from gear 4-3-2, but if you're not talking about 1 POP noise from exhaust, well i have that issue with my IS350 too, i think downshift from 3 to 1 car jumped a bit and it fells like a bad brake pad and rotor, someone just mentioned up there mine is AWD
A sound comes from the shift **** settling into place (by itself). It's weird and concerning at the same time.
Did my oil change yesterday, i've checked the Shift bracket under the car on the left of the Transmission where it connected to the shift ****, i saw there some kind of oil leaking from there, Mechanic said its not oil its Grease. i'm not sure but i do have this issue
I don't know about this clunk, but when I shift to park, the car jerks forward and the shift **** "slides" into place on P. This is even with the handbrake on.
you'll get it in cars that use an electronic shifter, too. but you just won't feel it in the physical shifter you place your hand on.
unknownkid (06-12-18)
drives cars
that's absolutely normal. the shift **** is physically connected to the transmission. depending on the load and position of the parking pawl at the time the car settles, you may feel/see/hear a slight click of the shifter. Just about every car does this that has a similar set up (which is 95% of cars)
Well I’m very late to the party but my 07 350 was doing the same thing, slow down cars in 4th gear come to a full stop clunk 1st gear, clutch was burned, replaced with a new unit now it’s al good.
