Having trouble with visor LED replacement
Old 01-30-15, 08:10 AM
ddvette9
ddvette9's Avatar
Default Having trouble with visor LED replacement
I changed LED bulbs on both map lights as well as the one on the bottom of the doors. When I went to swap out the vanity mirror lights, I could not figure out a way to pry off the plastic cover with my flathead. Is there a 194 wedge bulb in there and what is the way to pop the housing open and put a new bulb in there.
The map lights and lower door lights just kind of "pop off" once you wedge a small flathead in there. I tried the same thing with the vanity lights and didn't feel like I was getting any separation in the case.
Thanks
Old 01-30-15, 09:40 AM
Rebirthing
Rebirthing's Avatar
It's tighter than the lights at the door. The door one has the little clip you can release like an Ethernet cable, where as the visor one is more like a "surround" type that snaps in place.
Use a bit more force, and you should be able to get it out. (I used a small flat screw driver)
Not sure if this make sense to you at all or not....
Old 01-30-15, 10:23 AM
ddvette9
ddvette9's Avatar
I was able to pop the housing out and hold it in my hand but couldnt figure out how to get to the bulb inside and didnt want to rip the electrical wire as there is not a whole lot of slack.
Old 01-30-15, 10:32 AM
Rebirthing
Rebirthing's Avatar
It's the same way as removing / installing door LED. You can pull the wires out a little bit, it shouldn't break as long as you're gentle with it.
scottone92
LX - 3rd Gen (2008-2021)
12
08-08-21 07:53 PM
JJSoCrazy
RC F (2015-present)
41
05-25-21 08:55 AM
jbrittmart
10-27-11 11:44 PM
bigblack06
12-13-10 07:26 PM
Suprast4R
SC- 1st Gen (1992-2000)
05-22-04 12:07 AM
Quick Reply: Having trouble with visor LED replacement
