Wheel/tire size advice for 2014 IS350
Old 02-05-15 | 03:11 PM
Psych0man's Avatar
Psych0man
Default Wheel/tire size advice for 2014 IS350
Hi guys, I'm a noob with regards to this and I've done a lot of reading but still not sure if this configuration will work.
I just got a 2014 IS350 F Sport and I know the specs on my stock tires but I'd like to get a set for the winter.
I'm looking to buy used wheels and then set some new tires on them. The question is, will a 2005 IS300 17" stock wheels work with my car? Will there be any rubbing at all? Based on what I've read so far, it should be ok.
Bolt pattern is the same, width is 7.5 which is ok. What size tires would I get?
Thank you in advance for helping!
Old 02-07-15 | 02:45 PM
Psych0man's Avatar
Psych0man
Maybe I should ask a more specific question...
would 225/45R18 tires fit? I think the clearance would be just over 1/2" between the tire and the wheelwell. Would I get some rubbing?
MoabFJ
02-19-16 10:38 PM
AMSPHAN
Wheels, Tires & Brakes Forum
10-18-10 08:53 AM
MINI2na
06-08-10 03:32 PM
DaSyce
11-06-08 04:11 PM
