IS350 Brake VS F-Sport Brake
Old 02-05-15, 09:18 PM
Carlos9321
Carlos9321's Avatar
Default IS350 Brake VS F-Sport Brake
I know the F-Sport brake is 6 piston up front and 4 piston in the rear. How about the IS350 brake? Is it 4 piston up front and 2 piston in the rear?
Old 02-06-15, 02:24 PM
kinglexus99
kinglexus99's Avatar
I think the only difference is the type of pads used on the F-Sport vs Non F-Sport.
Old 02-06-15, 02:27 PM
JDR76
JDR76's Avatar
Received 1,621 Likes on 1,034 Posts
This was my understanding as well.
Old 02-06-15, 02:42 PM
4TehNguyen
4TehNguyen's Avatar
and its front pads only thats different on F Sport. IS350 gets the bigger brakes F sport or not
bhvrdr
bhvrdr's Avatar
Yes the FSport aftermarket brakes are 6/4 piston setup. Note that only the front Fsport upgrade fits. The rears are different from the 2IS to the 3IS.
The stock IS350/IS350 Fsport brakes are 4/1 piston setup.
Just as an FYI, upgrading to the Fsport kit will not stop this car any faster. In addition there are no problems with brake fade at all on the stock IS350 brakes. I was able to hot lap the car for a full hour at a time for 4 hours on OEM pads and fluid and went so hard on it that I overheated the transmission fluid (car and driver also did that) but there was zero sign of brake fade. Upgrading from IS350 brakes would be a complete waste. Now maybe upgrading from IS250 to IS350 brakes would be beneficial but I've never tested the limits of the IS250 brakes.
Mike
Old 02-06-15, 04:06 PM
unowned
unowned's Avatar
either you like them for "show" or you run R-comp tires at the track then you'll boil your brake fluid and might need the upgraded brakes
sirdizzle
11-21-18 09:11 AM
suginathan
Suspension and Brakes
11-08-17 06:51 PM
bazzle01
03-12-17 08:16 PM
forum429
05-30-14 10:13 PM
Quick Reply: IS350 Brake VS F-Sport Brake
