Setting enform remote start up to activate LED running lights?
Is there a way to program a 15 is with enform remote start to activate the day time running lights?
And change the settings that require you to restart the car once you get in after remote start ?
I am not sure on either of those as i would assume for the first choice, there would need to be some sort of signal wire that needs to run from the RES module to the DRL in order to activate it when you remote start the car.
for the second one, i believe it's been discussed before and you will not be able to bypass that as it was originally setup like that from Lexus as a safety feature.
But of course if you ever do either of them, let us know!
