Front Lip Protector?
Yours looks great. I didn't have much luck with mine. Prepped it and followed all directions, but even with the screws 1ft apart, there were areas that the tape didn't fully stick. Especially on the front bumper, near the curves, mine pointed down instead of extending out like yours does in the last picture. Oh well. Its definitely made of great material though.
They say cut small triangles but i say be more generous with the triangle cuts, you get more play to bend around the curve. the biggest curve is when you first put it on and at the end when it curves from a straight line. then there is a very little one that follows it. probably only needed to two cuts but i did four.
Video Quality Comparison
Video Quality Comparison 2
There is a major difference in quality. We are also a forum sponsor hear and as a forum member you receive 5% off. ClubLexus5
https://allfitautomotive.com/installation
Happy to hear they're product has worked out for you. Although we use the exact same tape from 3M just difference in quality of the lip itself. We supply the same strength tape, but ALSO included screws and washers for the most secure solution if the user chooses. Ours is specifically manufactured to withstand and protect unlike epdm which is what they use.
Glad to hear the product is holding up though.
It depends on where u want it under or stand up out , when u stick it u can move and fix it to any where u want , very easy . And with me i don't like it standing up and out , it will look like the thick bottom lip on the small face ew
With correct installation, our product is unbelievably secure, does not "flap" and will withstand any speed you could throw at it. We have tons of track guys rocking our product on their strictly track cars.
