Question/Help with Escort Passport Max Install
Old 03-22-15, 10:30 PM
rgonza1
rgonza1's Avatar
Default Question/Help with Escort Passport Max Install
I just ordered a Escort Passport Max with a blendmount vehicle mount for my '14 I350 F Sport. I do not want to run power through my car charger. My thought process is rather than messing with the electrical system and running a mirror tap I would like to run the wire through the headliner and down to the fuse box. I figure this way is much safer than getting into an argument with the dealer should I encounter any electrical problems. My question I pose to you all has anyone on this board done a wire directly to the fuse box?
I'm considering picking up these parts for this job:
Direct Wire Power Adapter Kit
https://store.valentine1.com/store/partsdept.asp
Bussman Fuse Tap
http://shop.advanceautoparts.com/p/b...h-rp/5080114-P
Anyone else have any experience with this job? I would like to tackle it myself.
Thanks
Old 03-22-15, 10:36 PM
computerwi
computerwi's Avatar
Yep. My dashcam is hooked up exactly the same way. I actually didn't even bother with the wire tap, I just shoved it into the switched leg of one the fuses. For my dashcam, the current draw is so low this isn't going to be an issue. I would check the power requirement of your radar detector first, although it's probably along the same lines as a dashcam I would imagine.
Here's a thread with a DIY where a member hooked up a radar detector and dashcam similarly.
https://www.clublexus.com/forums/is-...tallation.html
Old 03-24-15, 11:00 AM
anamynous
anamynous's Avatar
Just in case you haven't thought of it, have you considered powering it through your mirror's power source? I have the same detector and mount, and I also got the mirrortap from blendmount and it was super easy to install. And it looks really clean too.
Old 03-24-15, 04:34 PM
rgonza1
rgonza1's Avatar
I did consider a mirror tap. I understand that would be the logic and ease of install. However, I would prefer direct wire to fuse box in the event I have any electrical problems it will be a much easier conversation with my dealer that its ran directly to my fuse box.
jokim
12-27-13 04:21 PM
Superjatt
SC- 1st Gen (1992-2000)
07-25-11 07:01 AM
DRFT103
Performance & Maintenance
09-07-09 09:03 AM
LexusTexas
11-05-07 03:54 PM
Quick Reply: Question/Help with Escort Passport Max Install
