I just found this the other day under settings, I believe under the display section (or wherever it is you can change the needle color). Does anybody know what this does? I haven't noticed anything different since turning it on
Is this the setting where you can increase or decrease RPM? The ring on the tach meter will turn orange depending on at which RPM you want to light up. Minimum RPM is 2500 I think.
you can set for both RPM and for speed limit. I set mine at 4000 RPM so anywhere above 4000 RPM the ring will turns red. As for speed limit, I set at 70 mph and it will show 2 yellow dashes if I'm going above 70 mph and red dashes if I'm going over 100 mph
