Got a pics from further away? Curious about the look!
I will take some photos when the rain stops here.
It is fairly discrete and not as noticeable as I thought it would be, it might be because of that I didn't stick them out too much.
Also, if you know any local toyota stockist, you could probably get it as well coz it's the same product code as some toyota models are using the same flaps.
^ Let us know how well they attach and fit when you receive them.
Got them this morning from Lexus UK (invoiced with Lexus UK's letterhead) and proceeded to install the front set. Those china-made ones i had, had only two factory holes to secure onto the fender. However, this had four, three at the fender and one below, all using the factory pins to secure. It gives a snug fit with no gaps between the mud flaps and the car body. The material is different from those MIC flaps which were kinda stiff and hard to make it conform to the curve of the fenders, leaving a small gap that allows more dirt and water to seep through. Installation was a breeze as all one needed was a philips screwdriver and a pin-removal tool.
Yet to install the rear set, as that would require a jack which i did not have on hand at the moment.
