GS350 lowering springs on IS350?
Old 05-15-15, 12:39 PM
DanielCarv
DanielCarv's Avatar
Default GS350 lowering springs on IS350?
So I was wondering whether the RS-R down springs from a GS350 Fsport would fit an IS350 Fsport? Any information would be a great help!
Old 05-17-15, 07:18 AM
Sito514
Sito514's Avatar
I like to know also
Old 05-18-15, 08:06 AM
DanielCarv
DanielCarv's Avatar
So I spoke with a friend who works a lot in suspension , and apparently the springs do fit, but since a GS350 is much heavier than an IS, they require a larger spring rate. So transferring the GS springs to an IS would make the IS sit higher due to the IS's lack of weight.
Old 05-19-15, 05:29 PM
VMRWheels
Former Sponsor
VMRWheels's Avatar
+ 1
Probablyhas the same OD/ID so it can sit in the perch, however, is designed for a much heavier car.
You might see this same issue when people use springs from EX: ISF on an IS250. The ISF springs (because it has the larger engine and "heavier"front end) will make the front end sit higher if installed on an IS250.
GSLexTexas
10-04-16 08:17 PM
Yosevo
RC - 1st Gen (2015-present)
12-02-15 08:20 PM
Jay.Diem
Suspension and Brakes
12-03-08 07:06 AM
Quick Reply: GS350 lowering springs on IS350?
