Possible issue?
I'll try to explain this as simple as possible..I currently have a 2015 IS350 Obsidian with the red interior and the Navi system as well.
For those that know about the infotainment system, you can have 3 subwindows on your screen according to your selections. I have it set up as radio, navi and weather. Whenever I click into the radio to pull up the main radio screen, it switches back to the sub-window that shows the 3 sub-screens after maybe a few minutes. This is quite annoying since I would like to stay on the radio screen so I can view the stations.![Sad](https://www.clublexus.com/forums/images/smilies/sad.gif)
Is anyone seeing this as well? Not sure if it's meant to do this or if it's an issue.
I remember having this same annoying issue you did awhile back - but it's definitely a setting you can change ![Smilie](https://www.clublexus.com/forums/images/smilies/smile.gif)
I don't quite remember the exact menu navigation to get to the setting - but it will be something along the lines of auto change screens or something to that extent when you do find it.
Hope that helps.
Hope that helps.
An easy fix.
Menu > Setup > General > Auto Screen Change > Off
Thank you! I was wondering the same thing..
While we're at it.. I like to listen to the radio and nap in my car with the engine off during lunch.. it's an hour lunch, and i've noticed the power shuts off after 20-30 minutes? It's happened multiple times, kind of like how your computer would go to screensaver after X minutes. Anyway to disable this? I figure it's a feature to prevent battery from dying if you forgot to power off your car.
