Square Wheel Setup
Received 1,738 Likes
Best Square Set Up?
Looking to go square set up on my 2014 IS350
f-Sport. Considering running 18x9 et 35-40 with 255/35’s. Or 19x9 with 255/30’s. Has any run either one of these setups?
I think the main reason is that not a lot of rims come in 9 inch width that will fit the 3IS...due to the offset offered by the manufacturer,
If you can find a 9 inch +35 rim, then you're good to go.
The tire sizes you quoted will be fine as well based on the height of the rim.
Bumping an old thread...I'm looking to go square as well, considering 18x9.5 +38 with 255-40-18 all around. Any idea if this will work (particularly the front)? Online calculators say the front will be 12mm closer to the strut vs oem, not sure if there is enough clearance there. My fallback would be 18x8.5 +38 with 245-40-18, but I prefer the face of the 9.5.
^ use caution with too concave faces, they might not clear the calipers, make sure to do a test fit before.
I ran 245/40-18 on 18x8.5 +38 wheels and I had some rubbing in the inner wheelwell at full lock.
berserkr (06-21-22)
berserkr (06-21-22)
Anyone know if 245/40/18 will fit without any rubbing on a factory F-Sport wheels on the front? stock ride height as well.
I've heard it works on 2IS, but not sure on the 3IS.
I'm also on a 235 tire 9inch wide front rim on my springs, no rub
It will be on a 18x8 +45. I'm currently using 235/40/18 without any issues but I would like to go 245/40/18.
