Correct tire size 2014 IS350 20" wheel
In front I have 225/35/20 but that size is hard to find - so thinking to go 245/35/20 or 245/30/20. Think 35 will have rubbing issue? Is anyone running above sizes and what is your result? I am running 275/30/20 in rear going up from 255/30/20. Thanks for your help!
275 in the rear will be pretty risky to have unless you have a high offset wheel, it will be pretty darn close to rubbing if not rubbing on most setups. The 245's up front is pretty wide as well.
I have Michelin Pilot Super Sports, which run on the wide/square side in 235/35/19 (Front) and 265/30/19 (Rear).
With 19x8+30 (including 5mm spacer) up front, there's a slight minor rub on dips on the plastic fender liner.
With 19x9.5+39 in the back, the 265's rub on rear tapered bumper portion on major dips.
This is on RSR Down springs.
Hope it helps
Hope it helps
i have 235/35/20 Front with RSR half down Springs (Approx 1.2 inch lower) there is tiny bit rub when i turn the wheel to make a U turn or take a hard turn. other than that its perfect.
and in the rear i have a 255/30/20. no rub at all (also RSR half down Springs Approx 1.4inch lower)
the 255 gives the rim a better look and it will stretch as well. the ride is smooth but u will feel the road much more of course with tires as thin as 30mm and 35mm.
Hope Ive helped
emad2007
04-23-14 01:44 PM
I8ABMR
10-03-07 12:13 AM
